How Do You Remove the A-Pillar Trim?
Discussion in 'Model X: Interior & Exterior' started by PedanticOne, May 11, 2017.
  1. PedanticOne
    PedanticOne MyTesla Refresh Champion
    Bay Area, CA
    Trying to figure out how the A-pillar trim comes off. The top part that runs above the door seems to be what you'd want to pop off first, but the part towards the B-pillar seems to not want to be removed. So I'm perplexed. Anyone know?
    Speaking of the B-pillar, anyone know how to remove that piece of trim, too?
  2. oktane
    oktane Active Member
    Usually there is a screw under the SRS plastic cover on most cars A-pillar that comes out first. I forget what it looks like on the Tesla.
  3. PedanticOne
    Bay Area, CA
    Unfortunately, there is no such cover. There are two speaker grilles, but as I mentioned, there are two pieces of trim, the one that runs down the a-pillar itself, and another that overlaps it that runs along the top of the door. It's the part in the back near the magnet for the sun visor that I can't seem to get loose.
  4. PedanticOne
    Bay Area, CA
    I got it off. Just needed to use a stronger one of my trim tools. And there's a clip way back that's a bit of a pain, but ... success! The rest of the a-pillar trim is affixed with three bolts above the door and then clips down below. Just undo those, pop it out, unclip the speakers and done.
  5. oktane
    Thanks for the update, post pics in case someone down the road runs into the same problem!
  6. PedanticOne
    Bay Area, CA
    Yup. That's my plan when I finish what I'm doing... :)
  7. PedanticOne
    Bay Area, CA
    Here you go:
    • Helpful x 2
  8. Solarman004
    Solarman004 Member
    Colorado
    @PedanticOne , why were you removing the trim? Was this for a dashcam installation?
    Thanks for the video!
  9. PedanticOne
    Bay Area, CA
    Yup. I was installing a BlackVue. I did that one day and on another day I did the rest of the installation.
  10. PedanticOne
    Bay Area, CA
    Perplexes me why two people gave it a thumbs down. Oh well. I tried!
  11. Nerdy_Engineer
    Nerdy_Engineer Brett - The Nerdy Engineer
    Colorado
    Hmm, why did you go through the trouble of removing the trim? You can just tuck the cables in there without actually removing the trim.
  12. PedanticOne
    Bay Area, CA
    To be 100% sure I wasn't going to interfere with the airbag. I taped them up and out of the way to be doubly sure. Plus, why not learn?
    The only place I tucked the wire in was along the FWD.
