green1
Thank you, that was what I was looking for, combined with the pinout posted by others above.Some time ago I was considering if there was a way to do this. (Alter the adapter's current signal.)
I don't remember where I found this, and am unsure of its accuracy:
40 amps - 9.08k ohms
24 amps - 33.16k ohms
16 amps - 75k ohms
12 amps - 140k ohms
So the problem is that while I could easily add a resistor in parallel without wrecking my 14-50 adapter, that would reduce the resistance. You need to increase the resistance in order to specify a lower charge current.
You could put 160k ohm resistance parallel to the 140k of the 5-15 and use it in a 20A outlet. I've never tried that. I hope I never have to rely on 120V charging.
looks like my idea wouldn't work directly, but could still be useful if I were to modify the UMC a bunch (chop the end off and make my own suite of adapters with their own resistors, which isn't entirely a bad idea...)
