So lately, i've been frustrated by my Model S on FSD beta alerting me to put my hands on the wheel. That would be understandable, if my hands weren't already on the wheel. And yes, i have slight torque applied.
However, this seems to happen all of a sudden, with no warning, the red alert with beeping occurs without any the silent flash/warnings occurring. I'm just going along and WHAM beep beep beep, sometimes even going right to the red steering wheel warning, bypassing the passive and even first level red warnings, literally giving me a second or two to apply more torque to avoid a forced disable.
So I have a theory, and I'm curious if anyone else feels the same. I think many of assume there are several "stages" before forced disable. You must go through each stage one after the other and finally it shuts you out. I think that's wrong.
Instead, I think each type of alert (silent, red, red wheel, disable) has it's own timer and its own torque measurement. each stage has a progressively longer timer. So, let's say stage 1 is 5 seconds, 2 is 10 seconds, 3 is 15 seconds, disconnect after 20. Ok, but what can happen is you are applying enough torque to satisfy stages 1, 2, and 3, but not stage 4... so it silently jumps directly to disconnect after 20 seconds because you were just at the cutoff torque, failing to give you any warning whatsoever.
Anyone else feel like this is the case?
