How does the heater work?
Brian's ReX
267
318
Seattle
I believe (although others probably have much more intimate knowledge than I on this subject) that it is a resistance heater - which I have been told is why it is the single largest draw on the electrical system other than the motors.
Reactions: beachmiles
brkaus
7,633
6,163
Austin, TX
There is a many page thread in the model s forum here on the topic.
I agree it would have been a good choice.
There are some reasons this choice makes sense too. I won’t try to remember or rehash them here.
Big Earl
bnkwupt
Jul 12, 2017
4,915
8,790
Springfield, VA
Reasons include, but are certainly not limited to, increased cost, complexity and marginal energy savings in very cold climates.
jamnmon66
572
406
Brighton, CO
Too bad. A heat pump is much more energy efficient and they could have used the AC compressor.
But they don't work very well when it gets really cold & the efficiency goes down as the temperature does. At least that's true of my heat pump/AC in my house. I'm guessing a resistance heater is the most reliable option in all scenarios.
Reactions: Rocky_H
seyclone
89
29
NY
Thanks, all. I suspected that there would be a lot of posts on the subject. I guess I was using the wrong search criteria.
smith9
New Member
Apr 19, 2019
3
0
Brisbane
The problem is that while you may need cabin heat it is possible that you need to cool the battery and/or motor/charger/inverter at the same time.
Would't that be a good use of a heat pump, it takes hot air and expels cold air at the other end so one end of the heat pump could cool something and the other end can heat something, that way the heat pump is more efficient.
