stopcrazypp
As you noted before, the EPA efficiency rating (whether 89MPGe or the equivalent 38kWh/100miles) is from wall to wheels. However, the 85kWh number you are using is the pack capacity, not the number of kWh that would be needed from the wall to charge that battery (that number would be higher, probably closer to 100kWh). That is why you can't use the efficiency number and the battery capacity to figure out the range.Okay, so let's see if I've got this right:
According to that page, the EPA rates the S85 at 38KwH/100 miles "combined" which is 0.38KwH/mile
To convert that to miles of range, assuming that we can use all of the 85Kw battery (which of course we are prevented from doing so by the software), divide 85KwH by 0.38KwH/m to get about 224 miles. Which doesn't seem right. What am I missing here?
Thanks!
What I mean by simple math is that we know that you can scale the range numbers in proportion to the MPGe numbers.
So to figure out the city range, we take 88MPGe city / 89 MPGe combined * 265 miles combined = 262 miles city range.
For highway range: 90MPGe city / 89 MPGe combined * 265 miles combined = 268 miles highway range.
So from the city/combined/hwy MPGe of 88/89/90, you figure a city/combined/hwy range of 262/265/268.
