How does this bid sound for a garage outlet?
Discussion in 'North America' started by Effects, Aug 7, 2013.
  1. Effects
    Effects Member
    NorCal
    I would have liked a parts/labor breakdown. What do you folks think?
    ITEM DESCRIPTION Total
    Bid Run a new 50A circuit from the existing 200A panel. Consolidate circuits using quads and tandem breakers to make room (Cuttler Hammer 50/20 and 20A tandems). Use conduit inside the garage on the wall and provide a Nema 14-50 receptacle.
    520.00
    Sales Tax 0.00
    $520.00
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Sounds fair. I would check they are using #6 copper wire.
  3. spaghetti
    spaghetti Member
    Silicon Valley
    How long is the wire run?
  4. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    the quote is meaningless without knowing how far the future plug is from the panel..
  5. Effects
    Effects Member
    NorCal
    We are looking at 31 feet.
  6. JPP
    JPP Active Member
    SF Bay Area, CA
    You are using conduit. As a price comparison, I went to Home Depot on line and bought copper #6 4-wire (3 + ground) 'romex' for about $2/foot when I did my install. YMMV.
  7. Effects
    Effects Member
    NorCal
    Looking to having this done by an electrician.
  8. ckessel
    ckessel Active Member
    Seems fair. I think I paid less than $200 for about 20 ft of conduit and a 14-50, but I didn't have any breaker consolidation work.
  9. spaghetti
    spaghetti Member
    Silicon Valley
    Given the run length, conduit and breaker consolidation I think $500 is a fair price. I paid $800 for a ~60 ft run which had to go through multiple walls + a crawl space, along with breaker consolidation.
  10. FlasherZ
    The primary cost in these installations is labor and permitting -- where do I have to crawl, drill, finagle, coerce, cough-up-insulation, battle a 200-cell paper wasp nest, coordinate with a hopelessly busy inspector, etc. A 20' installation where fishing and drilling firewalls and such is required is likely to be more expensive than a 100' straight attic or basement joist run.
    Whether 6/3 Romex or 3x6AWG+1x10AWG THHN or even 4x6 AWG THHN, the retail cost is between $2.50 and $3/ft for the wire.
    Given the description $520 seems perfectly reasonable.
  11. TeslaSinHR
    TeslaSinHR Member
    Bellevue, WA
    If it is parts & labor it is fair. I think I paid $450. Most of the cost is the labor. I also asked that they use wiring that could handle 100 A so that if I decided to install an HPWC later, they wouldn't have to run new wiring - just upgrade the circuit breaker.
  12. PhilBa
    PhilBa Active Member
    Seattle
    As others have said, it looks reasonable based on distance and complexity. It sounds like a bit less than a day of labor. I'm sure you could find a cheaper bid if you worked at it, but not substantially lower. Personally, I'd take it.
