I run my battery down to ~10-20% then charge up to 90%. About every three days I charge.
So in other words exactly the opposite of what Tesla tells you to do?
Not really. I’m not full charging it and I’m not draining it. The battery is in the middle of its happy working range. We’ll see what happens.So in other words exactly the opposite of what Tesla tells you to do?
That’s why I wanted the standard range. It takes me too long to need to charge. Too much competition to get Charger daily so every three days will have to do.
theres no problem charging multiple times. In fact, the closer to 0% you run your battery when you charge it, the more cycles it will rack up. Keeping the charge between 40-80% is the best way to minimize cycles. it could be 10 or more charges in this range before it equals the degradation of one 0-100% charge cycle.
Why is there more cycles when charging lower than 40%? Isn’t one cycle essentially 0 to 100% ( yes I know one would never run to 0%) but isn’t 0 to 100 one full cycle. And 40-50% equal 1/10 cycle and same as 10-20% and 70-80% arnt those all considered 1/10 of a cycle?
So meaning if I did a 10-90% is the same as charging 50-60% 8 times?
I’m trying to understand why it’s better to charge 50-60% 8 times than it is to charge 10-90% one time.
Yes, really. Exact text from Page 111, "About the Battery" section of the Model 3 owner's manual (The emphasis is Tesla's):
"The most important way to preserve the Battery is to LEAVE YOUR VEHICLE PLUGGED IN when you are not using it. This is particularly important if you are not planning to drive Model 3 for several weeks. When plugged in, Model 3 wakes up when needed to automatically maintain a charge level that maximizes the lifetime of the Battery.
There is no advantage to waiting until the Battery’s level is low before charging. In fact, the Battery performs best when charged regularly."
Now, you may not believe Tesla. You may think you are "doing it better" than their instructions. But you are most definitely doing the opposite of what they're telling you to do.
Especially considering the 2170s are different than the 18650s, so the 3's BMS is different than the S and the X. What might have worked well in a previous Tesla may not work as well here.
The battery section of the Model 3 manual has exactly the same text as in the Model S and X manuals. Every Tesla owner has been given the exact same instructions since 2012, but some choose not to follow it because they think they know better, or think Tesla is just saying that so it’s less likely you run out of charge and has nothing to do with battery health, or because of something they remember reading or hearing somewhere about batteries.Especially considering the 2170s are different than the 18650s, so the 3's BMS is different than the S and the X. What might have worked well in a previous Tesla may not work as well here.
That is NOT the recommended practice. But it will be interesting to see if charging practices have any significant bearing on battery life. I charge to 90% daily as I know in the Roadster if you only charged to 80% the battery would never balance which also causes problems.I run my battery down to ~10-20% then charge up to 90%. About every three days I charge.
