How long does it take to charge a Model X 100D on Home Charger with 100A breaker?
The minimum for 72 amp continuous charge is 90 amp breaker. But if you have a longer wire run or smaller gauge wire you could need a larger breaker.On calc it says "Your vehicle is capable of charging at 72 amps. We recommend installing your Wall Connector on a 90 amp or higher circuit to take advantage of the higher charging capabilities of your Tesla."
What is highest breaker it will take/use ?
You can't upsize the breaker for smaller wire - you'll overload the wire and could cause a fire. For a long wire run, you'd want to upsize the wire, but not the breaker - the load through the breaker won't change.The minimum for 72 amp continuous charge is 90 amp breaker. But if you have a longer wire run or smaller gauge wire you could need a larger breaker.
You will need to consult wiring charts to see what the amperage is for a given conductor size, material type and distance. Then figure that you can only get 80% of the rated capacity for continuous power draw. So in the example you quoted the conductor did not come into play in the calculation at all.
I have the dual chargers on a 2015 Model S with a 85 kWh battery. The breaker is 100 amps, the maximum draw is 80 amps 240v, which adds 52 miles of range per hour, exactly as shown on the chart. When your Tesla wall unit is installed, be sure the electrician reads the instructions - the settings must be set properly to permit the output you expect. When my unit first went in, it wouldn’t budge above 40 amps until we reworked the settings.
What’s beautiful is a dual charger Model S on a 277 volt wall connector. 22 kW!
Yeah...
It is sad that they seem to have discontinued 277v support going forward. Reports are that existing HPWC units at 277v don't work with the Model 3, and the Wall Connector instructions no longer provide 277v as an option.
I am curious why they made the design decision to cut that as an option. Seems like it would have been a great option for commercial installs of the Wall Connector.
I keep hoping against hope that Model 3 gets a 72 amp option - it would be a real sick one
Nah, won't happen. The 48 amp charger *is* the fast one. The 32 amp one will be the slow one. Since the car takes less energy per mile 48 amps gives it tons of range per hour of charging. Nearly nobody needs that fast of charging at home or at work. They build cars for the mass market (especially the Model 3), not the .01% that have some weird use case. Do you have a need for a faster charger than the 48 amp one? If so, maybe you should just buy a supercharger. ;-) (I wonder if they would even sell you one?)
72? The HPWC puts out 80. Why waste 8 amps? But otherwise, I thought the same thing. It's disappointing how slow it charges. I still can't believe Tesla makes a HPWC that puts out 80 amps but makes no vehicles to take advantage of it.
I couldn't make it to my cabin and back in one day, which I often do, without dual chargers at 80 amps and a HPWC there
Plus. for destination charging, we will often arrive with a low battery at a hotel, and while we unpack and shower we have enough range for the night out, then charge fully overnight, and skip going to supercharger altogether.
I'm taking a trip from BC to Osoyoos then to Oroville, WA State's side of the lake, and there's no superchargers after leaving Hope, BC along the number 3 highway. There's a lot of Chademos but that's no good with the 3. Plus, a lot of 70-80 amp Sun Country and HPWC's -- and I need to drop my daughter off and come back same day -- but with the 3 I can only take advantage of 48 amps. I would have gladly paid extra to have that upped to 80! It's huge to some of us.
Even if you don't use it much, when you do need it, you usually really need it, at least in my view -- and after having that happen. So when I read your post I can't help but chuckle because I really want to take my 3 on this upcoming trip -- but may have to take my S -- because of the 3's undersized charger.
On the bright side, superchargers are planned for Princeton, and Osoyoos, but not until 2019, and even then I still want 80 amps for the other reasons.
