How hot is your Model Y?
acarney
2,735
1,702
Richland, WA
So.... just a little fun and curious post. It's ~96F out today in wonderful eastern washington state and I glanced at my Model Y to see how hot it was inside.... 147 F! I don't think I've seen it that hot before and that got me wondering what might come next week when it's supposed to be 115 F outside!
- What's the hottest you've seen your Tesla at inside?
- Is there a way to just turn on the fan via the app without turning on the compressor? I know I can pre-cool the cabin, but I'm just interested on circulating some air...
- When you vent the windows, does that turn the fan on any more? I feel like for awhile when the vent feature was just released it also turned the fan on...
I'll probably turn cabin overheat protection on starting this weekend and just set it to fan to let the car do it's thing. I normally don't turn it on just because I always pre cool the car before walking out to the parking lot and I would rather "forget" about that feature in the "off" position instead of being on a long trip somewhere and totally spacing out that I have it set to keep the car cool. I normally only use 1% to 3% a day from work and back, so it would be super easy for me to forget about this six months down the road until I do a roadtrip and draw the battery down to 20% or something while I'm parked somewhere, lol
phayze one
304
675
LA (818)
With cabin overheat off and sitting in the sun all day, it’s at 134F right now. Temp is 86F. I don’t have any tint but I do have a mesh roof sun shade up.
jcanoe
3,227
3,201
Maryland
Cabin Overheat Protection
The climate control system can reduce the temperature of the cabin in extremely hot ambient conditions for a period of up to twelve hours after you exit Model Y.
Touch Controls > Safety & Security > Cabin Overheat Protection and choose:
• OFF: Disable Cabin Overheat Protection
• NO A/C: Only the fan operates when the cabin temperature exceeds 105° F (40° C). This option consumes less energy but the cabin temperature may exceed 105° F (40° C).
• ON: The air conditioning operates when the cabin temperature exceeds 105° F (40° C).
NOTE: Cabin Overheat Protection operates only when the energy remaining in the Battery is above 20%
I recently parked my Model Y outdoors on a 90F day. Over 8 hours I estimate that Cabin Overheat Protection set ON used ~6.5kW of energy. (My Model Y has no sun shade, only the factory tint on the glass roof and rear glass.)
I have ordered a sun shade and will repeat this test soon.
The NO A/C setting may be a good compromise between not having any cabin overheat protection and using the AC. (Note: Cabin Overheat Protection is not intended to protect people or pets from exposure to high temperatures inside the Model Y, only for groceries and other items left inside the vehicle; perhaps the Model Y center screen.
acarney
2,735
1,702
Richland, WA
Ya, I'm familiar with the options, I just could swear last year there was an option in the app to turn just the fan on and not heating or cooling... I'm wondering if anyone else remembers that or if I was crazy...
jcanoe
3,227
3,201
Maryland
Do you mean leave the fan on all of the time (without the AC) once you exit the vehicle? Just turn off the blue AC button on the climate control screen set the climate control to remain on when you exit the vehicle (the option to leave the climate control on must be selected every time you exit the vehicle.)
Otherwise, you can use Cabin Overheat Protection setting for NO AC. (The Tesla vehicle will run the cabin fan to try and cool the cabin but will not turn on the AC.)
dino007
42
60
El paso
It was 101F today here in El Paso Texas and my model y was at 147F that’s the highest I’ve seen it which was interesting because last week had a couple of days at 108F but my model y was at about 120F no clouds either so yea was interesting
Yes I turned cabin protection off uses too much POWA in this heat IMO
RFM3_2018
44
37
I think cabin overheat protection doesnt go back on if the car has been parked for over 12 hours. Might be wrong though.
jcanoe
3,227
3,201
Maryland
If the vehicle is parked, and it has been more than 12 hours, if you unlock and lock the doors using the Tesla app the 12 hour clock resets.
GeezerSquid
Still a Geezer & Still A Squid
Jun 17, 2020
213
243
Baton Rouge, LA
The only time my Model Y is parked outside is when I'm out and about running errands. I leave the car set to Dog Mode with a set temp of 72-74. I HATE coming back to a hot car!! I charge my car each night starting at 10PM. The off-peak rate is 4.69 or maybe it's 4.89??? Anyway, it pretty darned low.
Reactions: ToasterStrudel
jcanoe
3,227
3,201
Maryland
Check your utility bill. Usually there are separate charges for power generation and power distribution. It might show $0.0469 per kWh for power generation and about the same charge per kWh for power distribution (power lines and infrastructure.) Add in taxes, tariffs and environmental fees and your total cost per kWh may well be more than $0.10 per kWh.
