A while back, I noticed that the air suspension compressor in my Model S was running quite often while driving. Then the air suspension warning light started coming on frequently. I started noticing a hissing sound from the front of the vehicle after parking. These symptoms were gradually getting worse and worse, week after week. My first thought was that an expensive air suspension system repair was in order, or maybe an air bag had sprung a leak and would need to be replaced.
Finally I decided I'd better dig in and see if I could find where the leak was coming from. So I removed the frunk so I could inspect the air suspension components in case there might be something obvious. Well, it took no time at all to find the cause of the problem - there was a lot of air leaking from near the air compressor hose fitting!
At first I thought the fitting itself was leaking, but when I removed the hose from the compressor it became obvious what had happened. The air was leaking from a hole in the hose itself. As it turns out, the air compressor hose was rubbing against an electrical cable and over time this caused a hole to develop in the air hose!
Now the fun part - fixing it! First I put the car in jack mode (to make sure the air compressor won't come on and ruin the fun). Then I mixed up a little epoxy and spread it over the hole in the air hose. Then I reattached the air hose to the compressor. To make sure the problem won't happen again, I used a cable tie I had laying around to tie the electrical cable out of the way. I let it sit for a couple hours before driving. So that was over a month ago - and the problem has not returned since.
So that's my story of how a potentially expensive repair was solved with a few drops of epoxy and a cable tie
Takeaway points:
As a preventative measure, you could check if the electrical cord and air compressor hose are rubbing in your vehicle. It would require removing the frunk and having a look (you can find instructions for how to remove the frunk elsewhere on this forum and on youtube). If they are rubbing, simply tie the electrical cord out of the way to prevent damage to the hose. Note that my car is a 2013 Model S - depending on the date of production, yours might or might not have this issue.
Also, if you are noticing increased run-time of the air suspension compressor, a hissing sound from the front of the car, or the air suspension warning light, you might first check if the hose has simply sprung a leak - it may be repairable with just a little epoxy and a cable tie!
Takeaway points:
