I guess EPA( or the Tesla quite close to EPA) range indication is quite overoptimistic( better then WLTP) but still overoptimistic.
Charging up to 100% would only be needed for a more exact knowledge of the maximum range that the car (BMS) will show. This for simple battery degradation calculation I guess.
As this is not very close to the true range a very cold winter day so to know the real range at a specific time I guess the Energy App on the Tesla screen is better. I have not used it at low SOC yet. It seems to calculate to a real empty batt and not take the brick protection in count ? Ye
I have Scan My Tesla and a ’21 M3 performance ( 82.1kwh branded battery).
Today scan my tesla reported 80.9Kwh nominal full pack. Calculation from on screen values gave me 80.2kwh.
I have done the check [ *Energy app 50km range* times *energy app consumption* divided by *charging state(SOC) on the screen*. about five times. Today, 54% SOC, 264wh/km, range 164km. OAT -21 C degrees and the car has been outside for more then 24h due to work on my daughters Audi.
Each time I have ended up with maximum 0.5 Kwh delta from SMT ”nominal full pack”, except for todays 0.7 kwh ( = 1% of total value).
Depending on the last month charging cycle the BMS could be more of than this anyway, so even with scan my tesla the value could be way more wrong.
I would say thar if the only thing youre interrested in is the nominal full( calculated number of Kwh from the BMS) you can do the on screen value calc, and be happy with that. Scan my tesla app+ ODB2 bluetooth dongle+ odb2 harness is not that cheap if you dont like to use it for other reasons.
I absolutely recommend SMT, its good to have
