How I Recovered Half of my Battery's Lost Capacity
I have a question for the knowledgable folks here.
I've noticed that when I come back from a longer drive, the reported %age and range "recovers" an hour or so later after the drive.
This last 50 mile drive came back with 37% reported, then 30-40 minutes later its reporting 42%
Max range has been hovering between 260-270 miles (2018 LR) with very consistent driving patterns so guessing BMS is really having a hard time figuring things out.
the car cant take a voltage reading while driving as i.e. pushing the pedal causes voltage sag. So after a long drive it will get a true voltage reading after the battery as cooled down and sat for a bit and then update the SOC%.
While driving the BMS only really has shutdown mode which engages when the voltage sags below a level which is safe (hence the acceleration dots at <10% SOC).
This has caused problems with fleet vehicles before which routinely supercharge to 100% and dont rest the battery properly.
Rated range gets updated in chunks by the BMS and is based on the CAC of the BMS which it learns from the voltage drop while driving.
% gets updated by the car monitoring the voltage x current draw and voltage drop which is only superaccurate at the high and low end really and will drift by a few % during the discharge cycle. (i.e. 98% accuracy still means you end up with 2% less range than you should have had) When the battery rests it does a proper voltage reading and updates the SOC%. It cannot do this when the SOC is between lets say 40 and 60% due to there being little voltage difference.
I observe that quite frequently. If you keep your SOC for a long time between 40-60% and then charge to 70% or to discharge below 30% there will be a large update of the SOC after sleeping. (i.e. up to 5%)
its obviously having a good think about it.
After charging last night from 43-90% after two hours it showed 85% :D
I'm presupposing that it didn't lose 5% battery all of a sudden to its just the BMS adjusting
Here is an updated view of my curve. I changed nothing, the BMS is just kind of wonky when making these estimates. Don't fret about it. You can go from dead last in the pack to above average for no obvious reason.
I agree. I did try to
Help my BMS by charging to
100% and letting it sit overnight at home not plugged in. Then discharged to “0” and let sit.
Let me know if you can tell where I did that based on my Teslafi graph.
I was charging from 50 to 70%, but in October, I switched to 60 to 80%. It might take a day (rarely) to use up the 20% range, to about 5 days, and it takes about 2 hours with the NEMA 14-50. Should I switch to the 50-70 strategy to minimize battery deterioration, keep 60-80, or something else? Thank you. Oh, 2021 M3LR with almost 10K miles here (1.5 years old).
The best to minimize long-term capacity loss is in general, is to reduce the average state of charge. So 50-70% should be nominally better than 60-80%. But 40-60% or 30-50% should be even better. Based on studies that @AAKEE has posted, 35-55% is a good spot, as 55% is just below the point where the rate of capacity loss climbs rapidly.
Just keep in mind that keeping the SOC in a narrow range will make it harder for the BMS to keep track of the actual capacity of the pack, so don't be surprised to see the estimated 100% charge drop. Don't worry, though, it's not actual capacity loss. If this bothers you, periodically charge to 90%, then let the pack discharge down to 10% or so while letting it sit for at least a few hours at those SOC levels, that will help the BMS recalculate the actual capacity of the pack - as suggested by this thread.
Hey, thank you very much for your excellent, and detailed post. I'm very glad you mentioned there was no need to actually do the full charge/discharge cycle, which I thought was necessary (I was about to do that again). I honestly don't care to see a high SOC, especially now that we won't use the car to travel (it's just a city car now), so I'm perfectly fine with lower numbers, knowing it's just a software 'glitch', and not an actual loss of capacity. So will switch to 40-60% now then. I don't want to go any lower, because my wife sometimes uses about 30% charge, and want her to have a cushion, just in case. Hey, one final question: Is it a good idea to raise that level in winter, like it was my understanding? Just to know for the next one. Thank you again for your great help.
Reactions: AAKEE
Yes, I'm with Dave on this. Very good post from Dave!
Just to ad: Its not sure you percieve a lower range. I charge to 55% for the normal daily drives, and use 20-35% daily.
My range havent really dropped at all over 37.000km and 1 year and 3 months. Imstead Im quite sure that my BMS cannot see the capacity loss and overestimate the battery capacity. My Nominal full pack is about 80.5 kWh, it was 80.6 the first day with Scan My Tesla, about one day after delivery/ 1000km driven.
according to my calculations my battery should have lost about 3% by now. This should mean that the battery capacity should be down to around 79.5 or so kWh. A few weeks ago I had a full charge, that did not change the NFP. Two days after this I purposly drove the car down to -2% SOC, as far as I dared to go, as I almost "knew" that there was a overestimate which would show up below 0% SOC. After a few hours with the car sleeping with -2%, the NFP change to 79.4 kWh. I think that my prognose was correct, and that it was close to the real capacity thqat I could see on the NFP at that time.
But it only took about a week before the NFP started ramping up to usual 80.5-or so-level.
So, the BMS estimate could go both ways. If using the low SOC principle to be kind to the battery, dont go too far below 0% SOC, as a possible overestimate will have the oversetimate hidden below 0%.
This is my teslafi degradation report just copy-pasted.
Reactions: Dave EV
I say just charge to 90%, experience the full power potential and enjoy the car to its fullest lol. At least that’s what I’ve been doing since I took delivery in sept 2018. 50k miles now and my full SOC is 285. there’s such a noticeable drop in power at those lower SOC’s.
Reactions: AlanSubie4Life
Sure - in the winter temperatures are lower and this naturally slows the rate of capacity loss due to calendar aging. So high states of charge aren't as detrimental when the pack is cold. The car is less efficient in the cold, so you tend to need more charge as well. At the end of the day, charge to whatever you need to get your driving done - after all, you bought it drive, not just preserve the battery!
Even though @AAKEE has really low rates of capacity loss due to his charging habits, part of that is also due to his cool climate - Texas will see higher rates of capacity loss than Sweden all else being equal.
Really good post!
The climate makes a big difference.
In Texas you probably have the double degradation compared to me in northern Sweden.
A preservative approach to how to handle the battery will probably reduce the degradation by 50%.
For example, my collegue with same daily driving has around 8% in his 3 year old LR, at 80.000km.
He use 70-80% daily and charge earlier on the night so he get more calendar aging due to higher SOC and longer time at higher SOC.
My car show no appearent degradation but there is/most probable about 2.5-3% degradation after 1.3 years. I actually got the BMS to briefly show 79.5kWh capacity by driving it down to -2% SOC, which is perfectly in line with my calcs.
According to my calculations i will have about 4% when my car is the same age as my collegue, and in that calculation I also will have about 20% more miles at that day.
To sum it up:
-Hot climate will easy double the rate of degradation.
-A conservative approach will cut the degradation in half.
Reactions: DrChaos and Dave EV
Like many others, I have been concerned with loss of 100% indicated battery range on one of my Model 3s. My P3D (build date 9/13/2018, delivery date 10/8/2018) had gotten down to 270.3 miles at 100% charge on January 20, 2020, at about 30,700 miles, which is a loss of 40.8 miles since the car was new.
I posted about going to the service center to talk with them about battery degradation, which I did on March 9, 2020. It was a great service appointment and the techs at the Houston Westchase service center paid attention to my concerns and promised to follow up with a call from the lead virtual tech team technician. I detailed this service visit in the following post:
Reduced Range - Tesla Issued a Service Bulletin for possible fix
While that service visit was great, the real meat of addressing the problem came when I spoke to the virtual tech team lead. He told me some great things about the Model 3 battery and BMS. With the knowledge of what he told me, I formulated a plan to address it myself.
So here is the deal on the Model 3 battery and why many of us might be seeing this capacity degradation.
The BMS system is not only responsible for charging and monitoring of the battery, but computing the estimated range. The way it does this is to correlate the battery's terminal voltage (and the terminal voltage of each group of parallel cells) to the capacity. The BMS tries to constantly refine and calibrate that relationship between terminal voltage and capacity to display the remaining miles.
For the BMS to execute a calibration computation, it needs data. The primary data it needs to to this is what is called the Open Circuit Voltage (OCV) of the battery and each parallel group of cells. The BMS takes these OCV readings whenever it can, and when it has enough of them, it runs a calibration computation. This lets the BMS now estimate capacity vs the battery voltage. If the BMS goes for a long time without running calibration computations, then the BMS's estimate of the battery's capacity can drift away from the battery's actual capacity. The BMS is conservative in its estimates so that people will not run out of battery before the indicator reads 0 miles, so the drift is almost always in the direction of estimated capacity < actual capacity.
So, when does the BMS take OCV readings? To take a set of OCV readings, the main HV contactor must be open, and the voltages inside the pack for every group of parallel cells must stabilize. How long does that take? Well, interestingly enough, the Model 3 takes a lot longer for the voltages to stabilize than the Model S or X. The reason is because of the battery construction. All Tesla batteries have a resistor in parallel with every parallel group of cells. The purpose of these resistors is for pack balancing. When charging to 100%, these resistors allow the low cells in the parallel group to charge more than the high cells in the group, bringing all the cells closer together in terms of their state of charge. However, the drawback to these resistors is that they are the primary cause of vampire drain.
Because Tesla wanted the Model 3 battery to be the most efficient it could be, Tesla decided to decrease the vampire drain as much as possible. One step they took to accomplish this was to increase the value of all of these resistors so that the vampire drain is minimized. The resistors in the Model 3 packs are apparently around 10x the value of the ones in the Model S/X packs. So what does this do to the BMS? Well, it makes the BMS wait a lot longer to take OCV readings, because the voltages take 10x longer to stabilize. Apparently, the voltages can stabilize enough to take OCV readings in the S/X packs within 15-20 minutes, but the Model 3 can take 3+ hours.
This means that the S/X BMS can run the calibration computations a lot easier and lot more often than the Model 3. 15-20 minutes with the contactor open is enough to get a set of OCV readings. This can happen while you're out shopping or at work, allowing the BMS to get OCV readings while the battery is at various states of charge, both high and low. This is great data for the BMS, and lets it run a good calibration fairly often.
On the Model 3, this doesn't happen. With frequent small trips, no OCV readings ever get taken because the voltage doesn't stabilize before you drive the car again. Also, many of us continuously run Sentry mode whenever we're not at home, and Sentry mode keeps the contactor engaged, thus no OCV readings can be taken no matter how long you wait. For many Model 3's, the only time OCV readings get taken is at home after a battery charge is completed, as that is the only time the car gets to open the contactor and sleep. Finally, 3 hours later, OCV readings get taken.
But that means that the OCV readings are ALWAYS at your battery charge level. If you always charge to 80%, then the only data the BMS is repeatedly collecting is 80% OCV readings. This isn't enough data to make the calibration computation accurate. So even though the readings are getting taken, and the calibration computation is being periodically run, the accuracy of the BMS never improves, and the estimated capacity vs. actual capacity continues to drift apart.
So, knowing all of this, here's what I did:
1. I made it a habit to make sure that the BMS got to take OCV readings whenever possible. I turned off Sentry mode at work so that OCV readings could be taken there. I made sure that TeslaFi was set to allow the car to sleep, because if it isn't asleep, OCV readings can't get taken.
2. I quit charging every day. Round-trip to work and back for me is about 20% of the battery's capacity, and I used to normally charge to 90%. I changed my standard charge to 80%, and then I began charging the car at night only every 3 days. So day 1 gets OCV readings at 80% (after the charge is complete), day 2 at about 60% (after 1 work trip), and day 3 at about 40% (2 work trips). I arrive back home from work with about 20% charge on that last day, and if the next day isn't Saturday, then I charge. If the next day is Saturday (I normally don't go anywhere far on Saturday), then I delay the charge for a 4th day, allowing the BMS to get OCV readings at 20%. So now my BMS is getting data from various states of charge throughout the range of the battery.
3. I periodically (once a month or so) charge to 95%, then let the car sleep for 6 hours, getting OCV readings at 95%. Don't do this at 100%, as it's not good for the battery to sit with 100% charge.
4. If I'm going to take a long drive i.e. road trip, then I charge to 100% to balance the battery, then drive. I also try to time it so that I get back home with around 10% charge, and if I can do that, then I don't charge at that time. Instead, let the car sleep 6 hours so it gets OCV readings at 10%.
These steps allowed the BMS to get many OCV readings that span the entire state of charge of the battery. This gets it good data to run an accurate calibration computation.
So what's the results?
On 1/20/2020 at 30,700 miles, I was down to 270 miles full range, which is 40.8 miles lost (15.1 %). The first good, accurate recalibration occurred 4/16/2020 at 35,600 miles and brought the full range up to 286 miles. Then another one occurred on 8/23/2020 at 41,400 miles and brought the range up to 290 miles, now only a 20 mile loss (6.9 %).
Note that to get just two accurate calibration computations by the BMS took 7 months and 11,000 miles.
So, to summarize:
1. This issue is primarily an indication/estimation problem, not real battery capacity loss.
2. Constant Sentry mode use contributes to this problem, because the car never sleeps, so no OCV readings get taken.
3. Long voltage stabilization times in the Model 3 prevent OCV readings from getting taken frequently, contributing to BMS estimation drift.
4. Constantly charging every day means that those OCV readings that do get taken are always at the same charge level, which makes the BMS calibration inaccurate.
5. Multiple accurate calibration cycles may need to happen before the BMS accuracy improves.
6. It takes a long time (a lot of OCV readings) to cause the BMS to run a calibration computation, and therefore the procedure can take months.
I would love if someone else can perform this procedure and confirm that it works for you, especially if your Model 3 is one that has a lot of apparent degradation. It will take months, but I think we can prove that this procedure will work.
Just getting to grips with all this tech flying around. Elon would explain in 1 mins but we know his time is more precious on other matters at the mo.
GREAT POST withGREAT DETAIL and explaation AND title !!! Thanks
ATB DSB UK
Hey All,
Is there any Cliff notes or numbered steps for this procedure?
From the first post on page 1
