Had a set of Hakkas on my last car. The best snow tire. Period. I've had others.TL;DR I drive a *ton* in snow/ice with Hakkapeliitta snow tires and full regen is the shiz.
When I was playing with this the other day on snow floor, I didn't feel the pulse of antilock brakes when I just lifted my foot off the accelerator (blended engaged). I had to hammer the brake pedal to get the antilock to go.Does anyone know how regen affects antilock braking? In other words, do you need to press the brake pedal for antilock braking to be active or will antilock braking activate while the car is braking regeneratively? I suspect that you need to press the brake pedal for antilock braking but I have not been able to confirm that anywhere...
Would be interested to know at higher speeds if you think about it, and are out in conditions like that.When I was playing with this the other day on snow floor, I didn't feel the pulse of antilock brakes when I just lifted my foot off the accelerator (blended engaged). I had to hammer the brake pedal to get the antilock to go.
Maybe at higher speeds it would have engaged.
You need to hit the brake pedal for ABS. This is the main reason full regen is bad on the slick. It will put the car into a straight slide.Does anyone know how regen affects antilock braking? In other words, do you need to press the brake pedal for antilock braking to be active or will antilock braking activate while the car is braking regeneratively? I suspect that you need to press the brake pedal for antilock braking but I have not been able to confirm that anywhere.
Now that we can set the car to blend regen and friction brakes do antilock brakes trigger when applied due to the battery being cold or full (i.e. while blending is active)?
It is no where close to the control of ABS.The car will automatically reduce braking when regenerating if it detects slip so yes, "ABS" works with regen. I put it in quotes only because it's not actually using the brakes but the effect is the same.
I am going to defer to @coleAK and say that what they are saying seems correct.Would be interested to know at higher speeds if you think about it, and are out in conditions like that.
Agreed, except it isn't just a feeling. I can attest that coming around a curve or corner, especially on a hill, you can kick out the back end at least a foot in that 1/10 second. And that isn't necessarily a good thing in traffic.All of them detect slipping and adjust, there is no need for low regen. Some people dislike the feeling of a tenth of a second of te back wheels slipping and thus prefer low regen.
once you overcome the force of friction and start to slide there is no going back… physicsAll of them detect slipping and adjust, there is no need for low regen. Some people dislike the feeling of a tenth of a second of te back wheels slipping and thus prefer low regen.
