There’s an outlet in a maintenance shed about 20 feet from my parking spot. It’s on the HOA’s Meter though. There’s also a breaker box in that same shed. I’d need to upgrade that panel, but if that can be done, I can get a 60amp circuit there and run directly to my spot. Then, the issue becomes installing a TOU meter and figuring out an easy way to track and reimburse the HOA.
Charging at work is not possible as I’m an independent contractor. While I park in the same lot everyday, there’s no power anywhere in the lot.
My coworker charges his M3 at his carport using the 110 on HOA's meter. He just arranged to pay HOA a fixed fee. It helps that his wife is part of the HOA board. For about 50 miles, you probably just use about $3 or less a day.
