I’ve been using FSD beta which is both impressive and problematic. But the real question is - if FSD is going to use camera only (radar and ultrasonics now removed), there’s a huge blind spot between the front windshield camera and the side fender cameras. At least half of my left and right turns require checking for cross traffic that there is no way either camera can capture. If you have a T intersection at a perfect 90 degree angle, the cameras can’t see cross traffic unless the car creeps out and angles itself significantly. This can never be a real solution, it’s too slow and dangerous. What do you guys think the solution will be?
