How is SOC or range calculated?
Discussion in 'Roadster: Technical' started by spaceballs, Aug 29, 2014.
  1. spaceballs
    spaceballs Member
    Sammamish
    Does anyone know how SOC or range is calculated on the Roadster? My fake sheet (bricks 46-54) has confused the roadster to drop it's range to 17 miles.
    Voltage SOC Brick
    3.91 84.11 1
    3.89 82.27 2
    3.91 85.15 3
    3.93 89.25 4
    3.93 90.02 5
    3.94 90.74 6
    3.94 91.23 7
    3.94 91.53 8
    3.95 92.47 9
    3.90 83.08 10
    3.89 81.28 11
    3.90 84.30 12
    3.92 88.24 13
    3.93 89.77 14
    3.94 90.23 15
    3.94 90.73 16
    3.94 91.54 17
    3.95 91.98 18
    3.90 84.30 19
    3.89 81.28 20
    3.91 85.15 21
    3.93 89.25 22
    3.93 89.77 23
    3.94 90.74 24
    3.94 90.73 25
    3.94 91.52 26
    3.95 92.19 27
    3.90 84.11 28
    3.89 82.27 29
    3.90 84.11 30
    3.93 89.25 31
    3.94 90.55 32
    3.94 90.84 33
    3.94 91.53 34
    3.94 91.76 35
    3.95 92.76 36
    3.90 83.90 37
    3.90 83.30 38
    3.91 85.15 39
    3.93 89.25 40
    3.93 89.84 41
    3.94 90.55 42
    3.94 91.23 43
    3.94 91.77 44
    3.95 92.48 45
    3.82 30.74 46
    3.81 22.61 47
    3.75 28.75 48
    3.82 28.83 49
    3.74 25.58 50
    3.80 45.06 51
    3.77 47.77 52
    3.78 51.28 53
    3.81 66.87 54
    3.90 84.11 55
    3.90 83.30 56
    3.91 85.15 57
    3.93 89.25 58
    3.93 90.23 59
    3.94 90.73 60
    3.94 91.23 61
    3.94 91.53 62
    3.95 92.47 63
    3.89 82.27 64
    3.89 80.33 65
    3.90 83.08 66
    3.92 88.24 67
    3.93 89.76 68
    3.93 90.23 69
    3.94 90.51 70
    3.94 91.23 71
    3.94 91.76 72
    3.90 84.11 73
    3.90 84.30 74
    3.92 87.23 75
    3.93 89.25 76
    3.94 90.23 77
    3.94 90.84 78
    3.94 91.54 79
    3.95 92.47 80
    3.95 92.98 81
    3.91 84.11 82
    3.90 82.27 83
    3.91 85.15 84
    3.93 89.03 85
    3.94 90.55 86
    3.94 90.84 87
    3.94 91.23 88
    3.94 91.77 89
    3.95 92.47 90
    3.91 86.20 91
    3.90 84.11 92
    3.92 87.23 93
    3.93 89.80 94
    3.94 90.55 95
    3.94 91.23 96
    3.94 91.56 97
    3.94 91.77 98
    3.95 92.49 99
  2. marco2228
    marco2228 Roadster Signature #34
    Cologne/Bremen , Germany
    17 miles in standard or range; ideal or rated?
    Standard could make sense. Range has to be calculated from the brick with the lowest amount of left energy.
    This is what I believe:
    SOC range in standard mode: 10 - 100 % SOC (not sure about the 10%)
    SOC range in range mode: 0 - 110 % SOC
    Your lowest brick has a SOC of 22% which is 12 % in standard mode.
    That would be 141 miles (rated?) for 100 % SOC.
    - - - Updated - - -
    That's strange. Brick #47 has a higher voltage but lower SOC...
    So the SOC seems not to be calculated from the voltage only.
  3. spaceballs
    spaceballs Member
    Sammamish
    Thanks Marco.
    It was in standard mode.
    Before the mileage drop, I said I had 144 mile range, I think I need to do more playing on the fake sheet and gather more data.
  4. spaceballs
    spaceballs Member
    Sammamish
    #4 spaceballs, Aug 29, 2014
    I noticed the lowest brick as I bring up the voltage on it, that range start to rise, seem like a direct correlation but I assume some SOC is factored in it.
    Sigh, I accidentally burnt out resistor R73 on the dc-dc converter... hopefully this will be an easy fix.
    Edit: BMB fixed, in case anyone cares, R73 is likely a current limiting resistor to the DC-DC converter, so if the DC-DC converter ever goes bad R73 will burn out.
