How many KW do Tesla's solar superchargers generate?
Discussion in 'North America' started by ratsbew, Jan 3, 2015.
  1. ratsbew
    ratsbew Member
    I tried looking up info, but came up empty handed.
    Any stats on the nominal KW (and kWh/day) that the solar superchargers generate?
  2. nwdiver
    nwdiver Active Member
    United States
    I counted 100 at Hawthorne. Panels that size are up to ~340w ea but most are ~300w. So Hawthorne is ~30kW x 4.5 hours/day = ~135kWh/day.
  3. ratsbew
    ratsbew Member
    Is 4.5 hours a good estimate to multiply a solar array by to figure the daily output? Obviously there are many hours where the sun angle is low and it doesn't produce its nameplate capacity.
  4. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    It depends on where you are. I'd recommend using PVWatts Calculator to get a fact-based estimate.
  5. Cottonwood
    Colorado
    PV Watts is a great tool to get detailed, more precise estimates, but 4.5 hours per average day for coastal California is a pretty good estimate. For the sunny southwest, it's more like 5 hours per average day. Those are averaged over a year. You have to also add a typical 80% efficiency factor going from DC at the panels to AC to the grid.
    Cottonwood Grove Annual Comparison shows the logged results of the 9.9 kW DC array at my house in Boulder. It has good southern exposure and is mounted on a south facing 8/12 (34˚) roof. I have had grid tied solar about as long as I have had a Tesla, and since I have owned a Tesla, I have produced far more electricity than my Teslas consume. The grid is a wonderful battery!
    Let's look at the average hours of production per day for my Boulder array, averaged over 6 years.
    14,182kWh/365.25days/*(9.9kW*80%) = 4.9 hours/day​
    I would use 250 Watts for a more typical production PV Panel today.
    100*250W*4.5hr*80% = 90 kWh/day​
    All those panels at Hawthorne produce about 2 or 3 charges a day... If Tesla is really going to produce enough solar to feed the Supercharger network, they will need some large solar farms in other locations.
  6. cpa
    cpa Active Member
    Central Valley
    Here in the Central Valley of California, our modest 2,590-watt system generated 12,722 kWh through our third anniversary date of installation. This averages out to 4,240 kWh/year. this gives an average daily rate of 5.6 kWh from July '11 to July '14.
