I think you misunderstood me. I'm saying that I recall that the EPA range value for the RAV4 EV was merely estimated/calculated (due to an exemption for low volume vehicles), rather than tested as most other vehicles are. Also, the calculation took the range estimate for a normal, incomplete charge and split the difference with the estimate for a full, extended charge. So the EPA number for the RAV4 isn't even estimated against a full charge. (They did this for the Nissan LEAF as well. Many of us wonder if this is why Nissan then dropped the feature allowing automatic charging to just 80%, thus giving them a higher EPA number.) I don't know how the EPA number for the limited Model S 40 was figured, or whether there's an adjustment to not count a full range charge for Tesla's other vehicles. I think I remember that the EPA doesn't reduce the range estimate on Tesla vehicles since the owner is free to set any limit on charge level, isn't that right?
I used the example of driving the highway just to illustrate what is possible with the vehicle. We RAV4 EV owners also get much more than the EPA estimate for mixed city/highway driving, but of course we aren't able or trying to simulate how the normal EPA test is done. (I find I typically get very close or even slightly better than EPA estimates for city/highway for most vehicles I've driven.)
Lastly, unlike ICE-based engines, it's common for hybrid and electric vehicles to do better in the city test vs. highway.
In summary, the 103 EPA range number is a poor estimate for the RAV4 EV.
Here the thing is... When Tesla Motors first projected range for the Model S, they did so presuming constant speed at 55 MPH. That was sufficient, they thought, because part of the EPA test -- which was only two cycles before -- was conducted at a constant 55 MPH. So the respective ranges were thought to be 320 miles for Model S 85, 230 miles for Model S 60, and 180 miles for Model S 40. That wasn't posted for very long. Very soon after, they lowered those estimates to 300 miles, 225 miles, and 160 miles, respectively. But, the final, official EPA numbers turned out to be 265 miles, 208 miles, and 139 miles instead.
Each of those represents a rather large dropoff from what Tesla Motors/Elon Musk expected to see. I believe they felt slightly betrayed by the EPA switching to a 5-Cycle range test. So yeah, each car is capable of achieving greater range than the EPA numbers, with carefully controlled judicious application of the GO pedal. Thus, I am not at all surprised that the RAV4 EV may achieve better results than the official EPA rating. My point is simply that its official EPA range rating is less than that of the Tesla Model S 40.
There is a reason for that. I believe it is at least twofold. Where the 2013 Toyota RAV4 EV uses a 50 kWh battery pack, of which 41.8 kWh is available for use, the 2013 Tesla Model S 40 uses a 60 kWh battery pack, of which 40 kWh is available for use. The RAV4 EV has a 154 HP motor rating, and the Model S 40 has a 302 HP motor. The RAV4 EV is front wheel drive, the Model S 40 is rear wheel drive. For those thinking in terms of ICE drivetrains, each of those is considered an advantage in favor of the RAV4 EV. More available capacity, lower power to suck away juice, and driving the front wheels all improve the efficiency of ICE -- so that should transfer to EV as well -- right? Wrong. Finally, the sole advantage that most perceived going to Model S 40 was its 0.24 coefficient of drag, as compared to the RAV4 EV having a 0.30 instead. But that advantage was only realized due to the 5-cycle test, as opposed to the previous 2-cycle test.
The fact of the matter is that EPA testing is largely not conducted by the EPA. The tests are performed by the manufacturers themselves, to specifications chosen by the EPA, using calculations that the EPA provides. The EPA will occasionally choose a car at random to double check its actual range and fuel economy rating, just to keep automobile manufacturers honest. That is what happened to Hyundai a few years ago, when it was determined they had flat out lied about the fuel economy for Elantra and Sonata, and had to pay retribution as a result. Because of this 5-cycle testing method, none of the initial Model S variants achieved the range that was originally hoped for. Instead, they got roughly 90% of their expected result. I expect that is similar to RAV4 EV, given your protests, because it uses a Tesla Motors drivetrain. But in any case, my point holds true -- the weaker motor and lower weight of the RAV4 EV does not translate into greater range than the Model S 40 -- despite other
'advantages'.
And this is why I rail against people who continually claim that the base version of the Model ☰ will have a 50 kWh, 45 kWh, or 40 kWh battery pack capacity -- but still achieve a 215 mile EPA rated range. Supposedly because of improved power electronics, improved coefficient of drag, and lower power motors. That is utterly ridiculous, given the evidence. However, it may still achieve a 215 mile range with perhaps a 55 kWh usable capacity, in a rear wheel drive car that has a software limited 75 kWh battery pack.
Here's some napkin math:
208 divided by 5 equals 41.6 ...
41.6 times 6 equals 249.6 ...
249.6 times 0.9 equals 224.64 ...
224.64 times 0.91666~ equals 205.92
That is a linear progression from the original Model S 60's range to that of a vehicle 80% of the mass using about 55 kWh instead. So, it is probably more than a little bit inaccurate, for various reasons. But it does get you at least 205+ miles of range. I figure various improvements over time in the technology used is what would get that
'extra' ten miles. Maybe.
But what do I know? I'm just some guy on the internet.
