What is the charging rate (miles per hour) for a Model S60 being charged with a regular 110 volt outlet?
Four is very good, two or three is more typical. If you have a 20 amp dedicated 120, you might get six.
I think I've heard it maybe 3 times? It's rare.MikingCO, when charging on 120 do you hear the coolant pump running continuously?
4 hrs of charging at 120vac meets most of my daily needs, but I'm concerned about coolant pump wear. 4 x 7 = 28 hrs per week of pump run time. Anyone else concerned with coolant pump wear, while slown charging?
The limit is 12A when plugged into a 15 amp circuit. With a 20A circuit and the UMC 5-20 adapter you can draw 16A.Isn't the limit 12 amps while charging on 120V ?
Those are real miles, when the car charges it shows you the charge in rated miles which are independent of how you drive.So 1.27 kw . If you average 3 miles per kWh , you get 3.8 miles .
However , if you are only averaging 2.5 miles per kWh (400wh per mile) you get 3.17 miles .
Theoretically, yes, but how many people have a dedicated 15A outlet in their garage?You can also convert a dedicated 5-15 outlet to 6-15, which is 240 V (15 A maximum). This would double the charging rate to about 8 miles / hour and I don't think you would need new wire, only a new outlet and a reconfigured circuit breaker. Link for the 6-15 Tesla adapter: Tesla — NEMA 6-15.
It's no different for a 60 than any other Model S.
I said of any Model S. The difference in consumption among the various Model S is not significant enough to materially change the charge rate. 120V 20A is 5 miles/hr plus or minus a fraction of a mile regardless of Model S. 240V 40A charging is 29 miles plus or minus a mile.Incorrect. Charge rate in mph is dependent on consumption, if you look at miles of range. Model X P90D would charge the slowest out of the Tesla fleet, Model S 60 would charge the fastest.
