anonim1979
Well said!Reading 110V and 220V is grating on the eyes. It's 120V and 240V. Been that way for more than 50 years.
Huh? I haven't had an EVSE quoted recently, but it seems most proposals still involve tapping into 2 of the however many phases come into your house.
Yes. You can't use both at the same time. Cars need to charge on a dedicated circuit-- or else make sure everything else on the circuit is off so it seems like a dedicated circuit. Better yet, install a new 50A circuit with NEMA 14-50 outlet. You're not going to be happy sharing a 120V circuit with a microwave.While we're on the subject, I might have a situation where I plug into a 120V outlet that has a microwave (garage next to kitchen) on the same circuit with either a 15 or 20 amp breaker. Are there issues with this situation?
Not all of those electrons make it into the battery. There is overhead. The OP should not assume more than 3mph on 120V. 4 if Tesla allows you to pull 16A on a 20A circuit (the plug with one blade vertical and the other horizontal is 120V/20A).
+1 ... which is why the 3 Volts in my family are charging on 120 ... My X gets to charge on a 240 14-50 tho which is useful after a roadtrip or to go from 90 to 100% SOC before I leave on occasion.Average American drives 20-30 miles in a day. At 3-4 miles range/hour off 110, you'll easily be able to top off the battery every night after a typical day. 220V is faster, yeah, but if you don't have easy access to a higher-power outlet, 110 will do just fine for most.
I go to some out of the way places that only have 15 amp outlets available. I get about 40 miles over night. So far it has been enough.The bigger question is, why on earth would anyone charge at 110/120v when there are an abundance of electrical chargers at 240, 350, etc except only in the most dire needs?
You can try dialing back the amperage (and thus your miles/hour charge rate), but in my experience it just doesn't work well at all and the car will refuse to charge.This may be stupid question, but what happens if it isn't on its on circuit? For instance, what if the garage door opener is on the same circuit?
Are you saying you'd prefer to drive to a public charger and charge there for a few hours twice a week, instead of leaving your car plugged into a 110/120 outlet at your residence, or am I misunderstanding?
It depends on what else is shared on the circuit and how much the circuit breaker is rated for.
If you exceed the rated current (amps) of the circuit breaker by enough amps AND for long enough, the breaker will trip. But if it only exceeds the rated amps by a small amount for a small amount of time, it shouldn't trip.
A garage door opener, which will see a split-second spike of power as it begins to lift the door, followed by ~10 seconds of more moderate power draw as it continues to lift the door, is unlikely to trip a breaker unless you're already close to exceeding its amp rating to begin with.
I charged my Volt with a 120V 12A charger on a 20A circuit that also shared a garage door opener and some lights and never had a problem. But on a 15A circuit it might have been an issue.
Because the 240V adapter that comes with the UMC is 14-50. Tesla hasn't made a 6-50 adapter since 2013. Look at Tesla's home charging page:Can one just use a 6-50 outlet, with two hots and a ground? Why run another conductor?
YesThanks. Is it possible to set the Tesla charging to any amperage? For instance, could I set it to 8 amps at 120V?
they seem to have one nowBecause the 240V adapter that comes with the UMC is 14-50. Tesla hasn't made a 6-50 adapter since 2013. Look at Tesla's home charging page:
https://www.tesla.com/sites/default/files/downloads/US/universalmobileconnector_nema_14-50.pdf
