How Many MPH Will Model 3 Charge From 110V?
I've been using 5-20 outlet (120v 20 amp), WITH 20 amp Tesla connector (you have to order it separately for $35), and I am getting around 5 mph. If you open the door and car starts up, the numbers will drop for as long as HVAC is running. A 5-15 outlet should net around 3 mph.
I charge almost exclusively on 120 V at work to avoid contributing to the competition for our two J1772 plugs.
I started out with the included NEMA 5-15 adapter, then shortly bought a NEMA 5-20 adapter from Tesla once I noticed that the outlet had a T-shaped receptacle, to increase the power delivered by 33%. My observations:
  • NEMA 5-15 (120 V at 12 A): 1,440 W = 4~5 mph indicated, 4 mph actual
  • NEMA 5-20 (120 V at 16 A): 1,920 W = 6~7 mph indicated, 6 mph actual
They're 12 and 16 amps instead of 15 and 20 because of the rule requiring de-rating to 80% for continuous draw.
At 16 amps, I replenish 60 miles over a 10-hour work day, which covers my 20-mile round-trip commute, plus an additional 40 miles.
Losses are presumably fairly close between these two so I'd expect the 5-20 to be 16/12 = 1.33x faster than 5-15.
No, it was documented here several years ago with the Model S that 16A charging is 42% faster than 12A, because once the overhead of charging is covered, all additional amps go to the battery. Model 3 should be similar.
There must be some truth to what you say since certainly some of the losses are a fixed amount per time but the ~ 10 - 12% losses we see at 7 kW (240v * 32A) charging implies a substantial loss component that is a fraction of the charge rate. I don't think it is explained by i^2 losses
With nothing on in the car, I get 5mph on the 5-15 120v connector. in my garage.
In the spring I plan a road trip across North Dakota. No Superchargers!. So the plan is to use Plugshare to find 240v locations where possible. Mostly, motels have 120v in the parking lot for ICE block heaters, but few have 240v. I plan to check into the Motel then go to a KOA or other RV park to get most of my charge, and walk back to the motel for the evening. When I have enough charge to get to my next destination. I will walk back and get the car. I will then park it at the motel and plug it into 120v for the rest of the night.
I do plan to get a 15-20 and hope to get 7mph with that. 7mph for a 16hr night is well over 100 miles.
Reactions: Oyinko
Do you get that on consistent basis? If you are sitting in the car with air running, then most of the power will go to HVAC. See what you gain over a 10-hour charge period. Is it 20 miles? 60 miles? This would be a more accurate estimate.
I did not charge it, just plugged to a 120V outlet to see that I would get and the car was showing 1KW - 2 miles per hour. The HVAC was off though. I can charge at home with 240V - 30AMP so I'm fine but I will be using a 120V outlet tomorrow in Santa Monica at my friend's house.
