How much electricity does it take to produce a gallon/liter of gas/diesel?
Status
Not open for further replies.
ElectroCat
26
81
Ont Canada
To get oil out of the ground, produce the gas/diesel and pump it into you car how much electricity does it take?
Electricity used
- Drilling takes huge amounts mostly produced by diesel generators
- Pumping
- Refining
- Pumping into transport trucks
- Running a gas station.
- I'am sure there are other electrify users in the process
Just wondering if the electric used to produce the gas/diesel would drive a electric vehicle further than the gas/diesel does?
If this is so then there is all the electrify that is needed to power electric transport available right know if it was not used to produce gas/diesel.
yerEVan
864
793
Near Philly
I think what is also mind blowing is how many resources are involved in fracking. That should be calculated too as there are vehicles that use natural gas.
sadly I’m guilty of having and using natural gas at home for heat . Looking to invest in solar.
Zythryn
Model Y custom Warming Stripes wrap.
Mar 18, 2009
2,168
1,189
Minnesota
And how much is used to make the solar panels wind mills or whatever?
Valid question!
However, where do we draw the line?
How much electricity/power is used to birth and raise the workers that build the solar panels?
For your question we also need to look into how much energy goes into building the wells and power plants that provide energy for fossil fuels used to power refineries, transportation and storage of oil/gas.
As for the OP question, you will get better answers in studies. The Governments GREET model is very in depth, however, it is a lot to dig through.
The Union of Concerned Scientists have done a lot of studies on transportation efficiency. All their stuff has full references and is much easier to absorb than the GREET models.
here is one paper they have done: New Data Show Electric Vehicles Continue to Get Cleaner
Reactions: iPlug
iPlug
444
637
Rocklin, CA
As Zythryn noted, this is really complex if looking for an answer with high level of precision.
If we are concerned about the fossil fuel inputs towards renewable energy generation, at a general level, more renewable energy (solar panel, wind turbines) begets ever lower fossil fuel requirements over time to manufacture them.
Picture solar PV, wind, battery storage renewable electricity powering the solar PV and turbine factories, workers vehicles, and even heavy machinery to extract and transport the raw materials throughout the supply chain. Same renewable energy would be used to recycle defunct solar PV, turbines, batteries...
Short story is it just keeps getting better.
SageBrush
REJECT Fascism
May 7, 2015
12,084
14,993
New Mexico
It is a rounding error ... as is the carbon footprint to make the machines and rigs and trucks and pipelines used in fossil fuel recovery.
Other than trying to muddy the waters, do you have something informative to contribute ?
nwdiver
7,432
9,441
United States
Electricity used
- Pumping
- Refining
The most common number I've seen is ~0.3kWh of ELECTRICITY per gallon. However refining requires a lot of thermal ENERGY. The ENERGY requirement for refining is ~7kWh per gallon but the most electricity you could get from that 7kWh is <4kWh.
Electricity is energy but not all energy is electricity.
Status
