How much electricity to produce gasoline?
Norbert
TSLA will win
Oct 12, 2009
5,410
1,626
San Francisco, CA
How can you tell it's only externally purchased electricity? I don't see that specified. Are you assuming that on site produced electricity doesn't enter the grid and isn't measured?
There indeed seems to be a lack of description on the site. It's my common sense interpretation, as it says "consumption", and I don't expect refineries to report internally produced and used electricity (see post #37 for a bit of description) (and even if it did, I wouldn't expect that to show up in this statistic). Also I wouldn't expect a refinery to feed electricity back to the grid and then consume it again (but even if it did, that's surely rare and I wouldn't mind that small number to be part of the statistic).
EDIT: In any case, the point is that refineries use more energy than that number, at least since they also use other types of energy.
jaanton
Roadster NA #1026
Jun 25, 2010
323
7
Oakland, CA
Years ago when the California Electric Power Crisis was going on, there was all this stuff about forcing businesses to cut power for health and safety stuff. The refiners got an exemption because their refining towers have massive electric fans which are pretty efficient when running but restarting them takes massive amounts of power. (Sounds like AC induction motors he he he) So much that they bring in semi-trucks of capacitors to help handle the surge. So they must be running 24/7.
vfx
14,790
40
CA CA
Gasoline's long tailpipe.
My car can run 30 miles on "invisible" gasoline.
Both Hydrogen and Gasoline add a step. Why not just put the electricity straight into an EV battery?
vfx
14,790
40
CA CA
Summery:
Yes we could supply the energy we need to drive EVs more than 50% of the miles we drive in a year from repurposing the energy we use just to refine gasoline.
And you mention that does no include finding drilling and pre and post refining transportation.
So to try and make this into a sound bite and ballpark the parts left out, Could this be the statement?
"If you took all the electricity it takes to find make and transport gasoline, you could drive an electric car 60 percent of the distance that burning that gas would take you."
(still needs work)
JRP3
Hyperactive Member
Aug 20, 2007
19,449
42,622
Central New York
Replace "electricity" with "energy" to be accurate, and maybe use "over half of all miles traveled" or "power over half of all vehicles on the road."
stopcrazypp
9,875
4,801
That's not completely accurate either. This isn't straight energy equivalency, but talking about using those energy sources to make electricity.
vfx
14,790
40
CA CA
vfx
14,790
40
CA CA
Feel free to use this when someone hits you with the "long Tailpipe" argument.
"I Want My Electricity Back! "
The big oil companies take the electricity that can go in our cars and use it all to refine it into
gasoline.
Then they re-sell it to burn in gas cars. Wouldn't you want to eliminate the middleman?"
JRP3
Hyperactive Member
Aug 20, 2007
19,449
42,622
Central New York
One problem with Elon's statement is that some of the energy used to refine gasoline is generated on site from petroleum by products and NG. Now we'd probably get more mileage if a barrel of oil were refined less and burned in a generating plant to charge EV's, but then we're still using petroleum for transportation.
