yobigd20
Get it down to 1 or 2 miles then blast AC in the garage til the car shuts down...
haha this is what i've done too. it actually goes down faster than you'd think. that AC is an absolute killer on range.
Intertesting, thank you for the info... How do you get it to exactly 0? Drive it around the block until it's at 1 then back and forth out of the driveway? haha
That's exactly what the Tesla rep told me to do though? So is it actual battery decay or is it just estimated range loss that can be recouped by charging to 100%, draining and charging back up?
Don't drive all the way to zero. I have done OK driving to about 10 or so miles rated range left. I usually do this on a road trip and modulate my speed and HVAC settings to use more or less energy such that when I get to about 10 miles I arrive at my destination. If you plan on going to zero and your range calculation is way off, you might find yourself stranded on the side of the road when you thought you still had 10 miles of range left.
It's a good thing for the battery, but 60% is especially bad for the calculation.
When you charge back up to 100% a few times (and let it sit there for a few hours), something happens... I don't think anybody definitely knows if it's just range recalculation or rebalancing. You may have some real loss in there, but you wouldn't know for sure until a couple of deep charge/discharge cycles.
I try to only do this on colder days (< 70 degrees). I know the BMS should cool down the battery, but Elon did give specific guidance some time back to not range charge it to 100% and have it sit in high heat for days at a time. Up to you though.
VERY true, I wonder how long it would take to get to from 10 to 0 by blasting the AC
In my experience, I have noted only 2 times where I had significant range loss over a relatively short period of time. 1) When charging to 70% daily. Although it seems to be recoverable range loss. 2) Driving the car very hard on a hot day with a low battery (<25%), this appears to be more permanent. Lost about 3 miles of rated range in one day doing that.
About 20 minutes.
I can only recall a handful of times where I've driven on a super low battery (it's pretty much always hot here though :frown ...
- - - Updated - - -
Wow, that's crazy... I'll get it to about 10 miles tho. But as other have noted, driving it at a low capacity when it's hot out damages the battery and, as I've stated, it gets very hot where I live (especially on the highways/freeways).
A couple of months ago i read somewhere on this forum that by charging to 90% you balance the battery pack a bit better so I've been charging to 90% daily over the last several months. My 90% rated range is now 235 and it continues to go up every couple of weeks. I believe the rated range when brand new at 90% was 238 miles.
That's insane, your battery seems to have done the best...My 2012 has 58,500 miles roughly. Battery pack was replaced at 19,000 (contactor failure - now they repair them).
So after 39,500 miles on my battery pack, the car range charges to 267, 90% charge to 239 - one mile less than when I got the battery pack.
I normally leave it at 90%, I range charge at will (probably once every 3-4 weeks). I charge at 80A all the time, and supercharge occasionally (probably once a month).
83k miles. Deliv 11-2012, s85. Range charge 5-10/yr, supercharge ave 4/month. 90% 221 rated miles and range charge last month was 282 ideal miles
Well that is incredible. I don't recall ever seeing an 85 with that high a range charge number, and certainly not after 83,000 miles.
