How much model x range lost overnight if unplugged?
Discussion in 'Model X' started by alexcuse, Dec 26, 2016.
Tags:
  1. alexcuse
    alexcuse Member
    Los Angeles
    New Model X 60D owner , formerly Leaf owner and didn't have this issue.
    I had about 16 miles of range last night, more than enough to drive to charger I thought. Go to car this morning 12 hours later and all of sudden 1 mile of range only.
    About 40-50 degrees California weather last night no snow. Read in some other threads from 2012 that model s loses 8 miles of range at night.
    Any updated info on how much does unplugged Model X lose per night in cold weather? Does hardware 2.0 make difference? Anything to turn off to lower this effect (I didn't check my car via mobile app last night though is always connected).
    I do wonder if I had checked one hour later would the car be compleyely drained at 0%? Or instead there was some safeguard to stop from draining more and leave at 1 mile minimum, if so would the drain have been much more than 15 miles overnight?
  2. carlshome
    carlshome Member
    Los Altos, CA
    If you read the manual it suggests always having your car plugged in when not in use. This way any energy needs are provided by the plug, not the battery. A large part of energy use when parked in very cold, or very hot weather, is keeping the battery heated in cold weather, or cooled in hot weather. So the energy used overnight will depend on the ambient temperature.
  3. leaf
    leaf Member
    London, UK
    This is a serious concern for me. I have a Leaf right now and it loses no charge overnight. I also don't have a dedicated socket as I live in an apartment building and have shared use of a pay-per-time charging spot. It's literally impossible for me to leave my car plugged in for more than about 12 hours. Didn't know tesla had this issue
  4. MorrisonHiker
    MorrisonHiker S 90D 2018.24.1
    Colorado
    Do you have Energy Saving Mode enabled? Also, you might want to check to see if Smart Preconditioning is on and if so, disable it.
  5. carlshome
    carlshome Member
    Los Altos, CA
    The Leaf does not heat or cool its battery. Which may explain why it loses no charge over night. But your concern may be overcome by the fact that the Tesla's range is significantly more than the Leaf.
  6. carlshome
    carlshome Member
    Los Altos, CA
    One more comment. I often leave my MX overnight without plugging in. Having it plugged in all of the time is not necessary at all. It is just Tesla's recommendation.
  7. Solarman004
    Solarman004 Member
    Colorado
    Energy Saving Mode: On
    Smart Preconditioning: Off
    Always Connected: Off
  8. Phil Seastrand
    United States
    Are you using any of the logging web sites? I was using https://teslalog.com and turned off the "Monitor Drive" and "Monitor State" settings and the parked usage dropped significantly.
  9. outie
    outie Active Member
    SoCal
    I have a 60D and I charged it to 90% overnight. I usually get 89% when I get in the car during the day.
    I unplugged it this morning and didn't drive it. It's been unplugged for more than 12 hours now and I have 86% left. This is with all power-savings off / always connected on etc.
    I go by % I don't go by the rated miles.
  10. FURY
    FURY Member
    DANA POINT, CA.
    Hi Outie!
    So, your car lost 4% in that 12 hour span, with always connected on, right? Have you measured the loss with Always Connevcted off?
    Thank you very much
    Fury
  11. Finder
    Finder Member
    Atlanta, GA
    I am finding that turning always connected off and energy savings on makes a big difference. I connected teslafi.com so I can track the specifics (I have sleep mode enabled too). During sleep time (when always connected is off it can go to sleep) I am seeing virtually no range loss over an hour time span. Over about 2 hours of idle time (when the car is still connected) I am seeing 1 mile of range loss in that time span. Not apples to apples but letting the car sleep seems far more efficient.
  12. outie
    outie Active Member
    SoCal
    It's now another 11hrs later and I have 85% left. It was 86% 11 hrs ago ~12am. So it's not very consistent. No I did not test with power savings on/always connected off.
  13. ptsagcy
    ptsagcy Member
    NJ
    Also, checking it with any of the app's wakes the car up which uses a little juice and extends the time that it "goes to sleep ".
  14. alexcuse
    alexcuse Member
    Los Angeles
    Thanks all, I turned on Energy Saving mode and the problem now went away. The app is now slower to load data from car but that is OK trade-off.
  15. Redmiata98
    Redmiata98 Member
    Northern Virginia, USA
    For reference, I have a 2015 P90DX and recently left it at National Airport in Washington DC for ten days. I had preconditioning off but everything else to include always connected on and did not activate power saving mode. The temperature dropped below freezing once or twice but probably averaged around 40 degrees F during that period. I am sure the battery heater probably activated a few times. During this period I lost about 7 miles per day.
  16. dark
    dark Member
    california
    Mine lose about 1 mile per day. I parked it for 3 to 4 days at a time. Compared to my S was losing 5 to 8 miles per day.
  17. bikeandsail
    bikeandsail Member
    United States, NE Ohio
    The always connected on seems to have a large effect on overnight drain.
  18. Milin1609
    Milin1609 Member
    Kingsland,GA
    I just went on cruise for 7 days and left My MX at New Orleans cruise terminal. When I came back, it lost about 10% battery. so, average about 1.15% per day. I think, it is an average. Thought about turning it off totally, but wanted to see, what happens in that condition.! I was happy that it didn't lost a whole lot more. I even checked from one of the port in the Caribbean, where I had cell signals available and it did connected and showed me the status of the car.
  19. gearchruncher
    gearchruncher Member
    Seattle, WA
    I've had my X for 50 days and have been tracking range loss overnight for 25 of those days. Parked in a 60 degree F garage, connected to WiFi. Range loss normalized to a full day:
    Always connected: Average loss 9 miles per day. Min 3 miles lost, max 24.
    Not always connected: Average loss 1 mile per day. Min 0, max 2.
  20. toxicpenguin
    toxicpenguin Member
    Greenwich,CT
    is there a way to restart charging from the app when it says "charging complete" but the car has lost range due to inactivity? The only way I can do it is to drag the slider on the battery to 100% wait for charging to start and the. and then back to 80%.
    Is there a better way of doing it?
