That is all good and peachy but those electrons just move to the other side of the battery. You need to use E=MC^2 to determine the mass differential. We did it before I'll look for the link.
or you can just put 85kWh into WolframAlpha
85kWh in g - Wolfram|Alpha
Ends up being 0.000003405 grams! So not grams but mircograms.
OK, I'm no expert either, but I really don't believe that E=mc^2 applies here. We're not converting matter into energy. No nuclear reactions, just simple chemistry. Perhaps we could get a real physicist or even a chemical engineer to chime in??
I suppose to carry this discussion further, how much younger do you get at max acceleration over 1/4 mile, will need some expertise is quantum physics here. Calculation may be easier using metric, so let's say 400m.
I realize of course there is more than one answer to this. :wink:
So where did the 3.4 micrograms of mass come from and go to?
What mass was transferred, created or destroyed (changed to/from energy) at charge time? At discharge time?
I really think the answer is 0 as when charging you move electrons from the cathode to the anode. Then as you run the car the elections migrate to the cathode. The batteries are closed loop.
