Possibly OT a little but, I was experimenting with the AC today, I have been for a few weeks. Trying to eek out the last ounce of cool air.
I've looked at the temperature of the air coming out of the vents to see what seems to work and played around with the flow a bit. All my testing was carried out with the demand from the battery being low, i.e. battery temp was down at rest.
One thing I did find was that the recirculate does actually work; having no discernible change in sound between on/off I did wonder but, with re-circulate on the air temp coming out of the vents does reliably drop 1-3*C after a minute or so.
It seems that the typical temperature of the output is around 7-10*C. It doesn't seem to fall lower and seems able, even in 38*C outside temps to stay in that range. This temperature is higher than other cars and why I think the AC appears weak.
So, how to keep cool? Well, I got to reasoning that, if the AC can keep up with demand then the problem is how to direct the output for the best effect. I found that pointing the vents directly at me is good for a few seconds but then you get that, what's it called, AC burn? where your body gets used to it and still feels warm. So that was out. I tried the control at 3 O'Clock directing the bulk of the air to the screen; the theory here was that, as heat rises the cool air should be directed to cool that hot air. This worked to a good degree and I found that I could stay comfortable for an hour at fan 1 in 30*C so, progress but, I was getting condensation on the windscreen - cooling energy was being wasted cooling the glass. So the next and final configuration worked for me.
To get the best effect, aim the vents at the source of the heat (physics students, stop laughing... this is my journey of discovery
. So, rotate the side vents to direct the air straight at the side windows; about 10 O'clock on the drivers side, and the centre vents upside-down and 50% open to direct cooing air straight up towards the roof - make sure no vent airflow is hitting driver or passenger directly. Set the output control at 9 O'clock to direct most air to the vents but leave some to cool the legs. Re-circ: ON. Fan at 1-3 as demand increases - Even at 3 the AC is able to keep up. The result is that a gentle cool air keeps your head cool (great phycological effect) whilst the thermal load from the windows is nullified by a wall of cool air to either side. Some air still leaks from the screen vents to prevent the build up of hot air under the windscreen.
One more thing; don't make the mistake I did and leave the temp control anywhere other than very minimum; I previously thought that the AC ran at some fixed rate (it does in the MINI) and that, as long as the heat wasn't on, it was cold; nope! If you turn the control up the AC power is reduced and the air from the vents does go up - Doh!
One regret; I wish the AC would output cooler air. I hear the compressor running at low to medium speed even with the fan (i.e. demand) at 3. I've heard the compressor run much faster... there's more life in her! Perhaps the external radiator is unable to shed the heat fast enough.
At this high level of demand total car power consumption is at 5A.
These are my findings, try them out, let me know if you can find another ounce of cool air; it'd be much appreciated!
