I have a theory which I realize I don't have any basis for, so therefore I ask you this:
For identical scenarios, will track mode with 0 regen affect how much regenerative braking is used when applying the brakes, or will it be the same as if you didn't have track mode on?
I thought the regen settings only changed how much passive regen braking was used, not while actively pressing the brake pedal.
I'm not looking for "if you don't have regen you probably have higher speed and need to brake harder", I'm wondering how that setting affects the car, not how it affects you.
