whttiger25
I drink Dos Equis?
I drink Dos Equis?
Time spent at high charge voltage is what causes dendrite growth and thus capacity loss. The less often you get your cell above 90%SOC the longer your battery will last. The below chart isn't specific to Tesla batteries, but the basic principle still applies. To extract the most energy out of the battery over its life time the best bet is to cycle it between 75% and 65%. This is not practical though, but widening it to 75%-25% (50% total battery capacity) will still get decent range and really dramatically improve the lifetime of the battery.
Compare the 75-25 and the 100-50 lines below. Same amount of energy used, vastly different lifetime results.
Obviously this is not practical all the time, but keep it in mind when you are planning your overall charging strategy.
-Jim
what is a DST cycle in terms of miles for a typical Tesla?
sdorn is right. DST is Dynamic Stress Test and is intended as a rough equivalent to discharging while driving. The number of miles depends on the total amount of SOC reduction. For simplicity sake, if 100% battery gives you 300 miles, then the 50% SOC lines would give you 150 miles. 100->50 and 75->25 will both give you the same number of miles.what is a DST cycle in terms of miles for a typical Tesla?
I don't think that's how the chart works? i.e. 75-65 isn't considered a cycle, it's considered 1/10 of a cycle...If looked at the total miles as a percentage for each to get to 90% of capacity. The one that produces the most miles is the 75-25 cycle with an estimate of 371,925 miles on an 85D. The 75-45 is a close 2nd at 369,360 miles. Interestingly, the 75-65 is the 3rd lowest at only 218,025 miles. This tends to back up the theory that a lower state of charge is best. It also debunks the theory that smaller charging increments are better. I would like to see a line for 50-25%.
I used 270 rated miles at 95% capacity (assumed half way wear point) with the swing in percentages, and estimated the cycles to get to 90% capacity based on the chart.
I bought the larger battery. It charges faster. I have lots of range, even at 90%. I have no need to charge to 100%, even on long trip legs. Since I know how far I can go, I don't understand why anyone would charge to 100% for no reason, or drive the car down to 5% or so for no reason (or "reasoning"). The car tells me how far to the next charger or supercharger or address, to the mile. It gives me the charge I have, by the mile, and I know to add a percentage if I plan to drive FAST or UPHILL. It's not that hard. It's not a gas car where you can't tell how far you can go.
So what's the worry about having to charge to 100%? It takes a lot longer, and there is some evidence that it might be hard on the battery over time. Sounds dumb to me. Just like driving it down to low charge numbers. Why do it?
Nope, each charge->discharge "set" is a cycle so from 75%->discharge to 65%->charge to 75% is one cycle.I don't think that's how the chart works? i.e. 75-65 isn't considered a cycle, it's considered 1/10 of a cycle...
-Jim
As I understand, sometimes it's actually beneficial to the battery to fully fully charge it because it balances the cells.[/QUO
Yep. Which is exactly what tnt1971 did.So then another factor to look at is the number of miles you get out of a cycle...
Great analysis! Me too, but I'd bet the difference between starting at 75% vs. 50% is not that great. There actually may be some loss due to the fact that batteries heat up more (with same power output) the lower their SOC is. It would be an interesting number though.I would like to see a line for 50-25%.
Kinda... for somebody who doesn't really care like a lease owner, then yes they don't need to worry about this at all. However, I'd bet that even within 45000 miles you'll see appreciable degradation if only using the car from 100->80 and charging every day. Not enough to matter over 3 years, but it will make a big difference for the follow on owners.All of this reinforces the fact that it is basically meaningless over the life of a 45,000 mile three year lease. For longer term owners, according to the U.S. Department of Transportation Federal Highway Administration the average American driver logs 13,476 miles each year. That means you are at almost 15 years of driving just to hit 200,000 miles for the average American.
So what is the time estimate that is safe to leave the car charged to 100% before driving off? Is it five minutes, one hour, six hours, 12 hours etc?.
"do not let the car sit at 100% soc for an extended amount of time"
if your daily driving needs can be met with that level of charge that's great but be aware that maintaining a very low SOC is detrimental to the battery as well.Several people have written that the size of the charge/discharge (i.e. 90-10 versus 90-70) is a very important, if not the most important factor in battery life. The chart does not bear that out because the smaller swings do not lead to more mileage out of the battery. As Dahl says in his talk, the SOC seems to be the most important factor (he also says temperature, which the chart kept constant). I will continue my practice of keeping the battery between 20% and 40% most of the time, with higher charges for trips.
