After many supercharging sessions my experience is the same. The good old pairing system is still in place.
With sharing, no, they are not ever tied more than a pair of two. But it does sometimes happen that a whole site is having power supply problems, and several of the pairs are having a hard time getting high enough power levels.Would more than one pair of charger connections ever be connected to the same charger? On one trip three of us ended up believing that #2A,2B,1A&1B were all effecting each other..
This. Superchargers are really hard to diagnose sometimes. There's a ton of factors that could affect charging speeds. Overall site power issues? Bad charging handle? Hot? Failed chargers inside the stack? Gunk in your charging port? Plus a ton more potential things. Any one, or any combination of many combine and make it tough to pin down the actual reason your one charge session is slower than normal.With sharing, no, they are not ever tied more than a pair of two. But it does sometimes happen that a whole site is having power supply problems, and several of the pairs are having a hard time getting high enough power levels.
Hmmmm, not sure that is a step in the right direction. At least here in the Midwest where SC's rarely see another car, let alone be concerned about pairing. How do they define "urban"?
People always suggest using colors, and then people always have to remind them that some people are color blind. The numbers and letters are good, but at the top instead of bottom would certainly be easier to see.
The most confusing I have seen is Beaver in Utah. It had 4 and they added 4 more. he first 4 are 1A/1B/2A/2B the next 4 thy installed ar the other way! 3A/4A/3B/4B
What happens with model 3, since it charges at 150kw? Will a second car plugging in case it to drop to 108kw so it can give the second car the 36kw minimum?
I'm still experiencing the same behavior on V2 equipment that I always have. First car gets full power (144 kW), second car takes a quarter of the power (36 kW, dropping the first car down to 108 kW) until the first car's draw drops below half, at which point both cars get 72 kW. When the first car drops below 36 kW, the second car has up to 108 kW available. Urbans have a fixed split at 72/72. Superchargers in need of repair will output less power.
That used to be what I experienced. But no longer (within the last 90 odd days anyway). Someone fires up next to me, I drop to 72. Happened in St Charles MO, Fort Wayne IN, and Louisville, KY. It used to not matter, since the SCs in the midwest were largely deserted. Now though it is not uncommon for SCs to be more than half full.
Yeah, I've seen many reports across a few sections of this forum of this behavior being changed some time in the past few months. Some? Most? All? of the 150-type Superchargers are defaulting to a half-and-half split when a second car plugs in, even if the Primary car was still supposed to be getting over 120 or 130kW.That used to be what I experienced. But no longer (within the last 90 odd days anyway). Someone fires up next to me, I drop to 72.
I still haven't seen it investigated enough if this was some intentional change Tesla did, or if there is getting to be some frequent software glitch that is causing them to default back to some failsafe mode with that half and half functionality.
I like that theory. It seems like a sensible thing for them to do to make better utilization of the equipment.I supercharge daily at different stations. The behavior has not changed across the board. Sometimes it seems to split 50/50, sometimes it seems the first come, first served method is used. I believe what really happens is they might try to optimize the load. Since 3 charge units always switch together, there are often situations where one car only uses a set of 3 units partially which then isn't available to the other one. I believe they changed it to minimize idle charge units. For example if car 1 charges at 80 kW, 28 kW are unused. I believe if there is a paired car 2 plugging in, car #1 gets capped to 72 and car #2 can use the remaining fully. I believe that's why it sometimes looks like a 50/50 split.
I hope you're right, because an even split is nicer than the trickle of power that comes from the original configuration.
