Nick77
Deep Blue Model 3 LR (2021 MIC)
NFC, not Bluetooth.what you think happens, when you have your phone, not touching an app, walk to a car, touch handle and it unlocks?
I doubt that, you don’t have to get that closeNFC, not Bluetooth.
NFC works on some Android phones but you have to hold it against the reader as you do with the keycards.NFC, not Bluetooth.
...Thoughts...
I generally switch off bluetooth on my phone. As it's Android, you can use NFC by touching where the keycard would be used on the door pillar. If you're quick to start the car/get past pin to drive, you don't need to use the card on the centre console or switch on bluetooth. If I'm slow, I'll generally put bluetooth on, but I'm already in the car.
You lock the car using phone/NFC on door pillar.
Normally phone plugged in charging by then, easier to just sweep down and switch on. Didn't think to use NFC on console. Might do that sometime to see which is quicker. Habit might be the deciding factor.If you normally lock/unlock using the phone NFC, any reason you wouldn't simply delete the bluetooth phone key rather than switching the phone's bluetooth off ? Genuine question because that's what I do because the bluetooth phone key remains active for too far inside the house, so just use the phone NFC like the keycard.
Based on the situation you describe, if you're slow getting in the car then personally I find it less hassle to unlock the phone and waft it on the centre console than it would be to unlock it and turn bluetooth on.
Recently tried using the bluetooth phone key again because the phone NFC often seems slow to unlock (or there's a knack I'm missing) and turning bluetooth off at home, but kept forgetting to disable bluetooth so went back to phone NFC only.
Don't forget worrying about finding places to park where you can install your window blinds and camp-out.I'm getting more convinced Tesla owners are the type that also suffer from hypochondria because they seem to generate a new worry each week, everything from PPF - do i inform the insurance company to fitting mud flaps will it decrease range.
How far are they actually going to get if they did steal the car? With it always talking to the Tesla system it’s just going to get shutdown. It’s not like they can mask it as another vehicle or ship it off to Eastern Europe.
