Which app?Thanks for the app. I like how much more info it gives me than any app so far that I have used for that.
He's referring to the TezLab app that was mentioned in this thread.Which app?
While 50% would be optimal it's not particularly harmful to have batteries sit around at 60-70% and it'd be a lot more convenient to have a little extra charge if you actually wanna go for a drive. If you have a performance model also remember that the horsepower will drop a lot once it's under about 70%.
I'd probably just set it to 65% or 70% and keep it on the charger. Really wouldn't be a big deal. If you're really super paranoid I guess you can do 60%. Just remember to occasionally do a larger charge and larger drawdown or the BMS will lose accuracy.
Looks like best thing is to keep it plugged in when not driving for a few days and at 80-90% SoC.
I don't have an option of charging at home so I charge the car at superchargers and sometimes at my parents. To be honest with you after reading so many posts and do's and don'ts it makes me feel like I'm not supposed to own the car because I don't have a place to charge and the battery will lose charge and charging capabilities. I just think do what you feel and enjoy the car, no matter what you will do there will be someone who will say that's not the way to do it or it's the way to do it. I personally enjoy the car and it's parked 4-5 days a week, yet it's amazing to drive and I have a lot of fun doing it, even if I charge it at the supercharger 90% of the time.
Thanks. Based on the link to the BMS thread in the M3 forums, this sounds like what I should be doing. Vary the percent charged amount, let the battery consume down to 20% at least once per month and charge back up to a different percent.
Based on my daily mileage needs, I think I'll be good with just using the existing 110v outlet in my garage and I won't need a 14-50 or a WC installed....but I may still get some quotes from electricians to install.
Agreed, 110V is fine IF your driving habits are predictable and your daily commute is relatively short. Or maybe you work from home like a lot of people these days. Think about it this way, you can get about 10% = 50 miles of range in a 12 hour overnight charge from a normal 110V outlet. As soon as I learned that, it was like, this is perfect for my wife and my lifestyle. It sure is nice to plug into a standard wall outlet! We charge to 79% consistently and then charge up to 90% the night before we are going on a longer trip. So far so good.
This discussion is only about battery longevity optimization in cases where that is easily doable. In all other cases I would say, use the car normally, and avoid charging to 100%, unless you are going to need it. Perhaps your battery wears out a tad faster, but that doesn't mean you have to lose sleep about it. What's so bad about buying a replacement battery after 10 years?
The only issue with 110/120V is that it could potentially not charge or not charge in amounts significant enough to add range to the battery. The battery needs to be warmed to a certain point before it will add “range”.
Also, you will lose range if you precondition in the winter months. This is fine if you are anticipating it, just noting you should be aware of waking up to 30-40 miles of range gained overnight compared to 50.
If you can’t install a 240V circuit, there are options for 120V such as the 5-20 outlet or TT-30. But contact an electrician to make sure these options are viable for you and your wiring. If you do not have the proper wiring or breaker, you have a substantial risk of fire.
