View attachment 389598 View attachment 389599 I was able to improve this by adjusting the plate near the gas strut anchor. This appears to be the place to make adjustments for the alignment of the top.
The two bolts are shown in the photo below.
Remove the gas strut and loosen the bolts. The original paint marks where it was painted so you can always put it back to the original location if that becomes necessary.
Very small movements are needed. Then you will need to snug the bolts and check the alignment. If you go too far you will potentially ruin the figment with the latch or the other side.
This would be easier with a helper.
With these bolts just slightly loosened you can move the hatch forward and back, up and down at least a few millimeters.
It’s better now. I would need a helper and more patience/time to get it better.
