How to charge between Santee, SC and Leicester, NC - 230 miles
Discussion in 'Southeast' started by holstein13, May 24, 2014.
Tags:
  1. holstein13
    holstein13 Member
    South Florida
    I need to drive from Fort Lauderdale, to Leicester, NC on June 6th. It looks like there are superchargers all the way up to Santee, SC, but then I need to find somewhere to charge between there and Leicester, NC. Just outside of Asheville, NC. 230 miles and a few mountains in between.
    I have the P85. I'm thinking Spartanburg, SC would be the ideal place to charge, but I'm looking for suggestions on the fastest way to charge with the best distraction available while charging. Good shopping, dining, entertainment, etc. available to pass the time. How many extra miles of charge do you recommend?
  2. CHGolferJim
    CHGolferJim Member
    Chapel Hill, NC
    #2 CHGolferJim, May 24, 2014
    Will be close in terms of completion date, but the Greenville SC SC is under construction (search TMC).
  3. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    If Greenville is not done, I would stop in Columbia, SC and get a couple of hours there. According to Plugshare there are dozens of J1772s.
  4. trigga71
    trigga71 Member
    SC
    I charge in Columbia almost every day. The public chargers I have been to charge at 18/19mph. But I do see a few Teslas up there so maybe an owner could give you a charge
  5. Chipper
    Chipper Active Member
    Chattanooga, TN
    If it were me I would prefer to adjust my speed rather than spend hours at a low-volt charger. 230 miles is doable in a P85 if you can hold your speed in check.
  6. drewnick
    drewnick Member
    Boca Raton, FL
    The elevation change from Santee to Asheville area is going to mostly preclude doing this nonstop. That blue ridge escarpment will be pretty harsh, plus lots of rolling hills between Columbia and there. I'd expect the Greenville supercharger will be done by then, based on the progress. It's then a straight shot up HWY 25 to Hendersonville and back on to 26.
  7. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    #7 wk057, May 25, 2014
    I did Santee, SC to Hickory, NC (205 miles) without any issue a couple of weeks ago... was around 305 Wh/mi. Heading further west through the mountains will be a little more challenging, but I did Burlington, NC to Canton, NC (west of Asheville) without issue, and I was able to keep it around 310 Wh/mi with some basic hypermiling techniques, which are easy to do in the Model S! Charged at J1772 charger in Asheville at a Mercedes dealership for a while to get back to my family location.
    There is a HPWC (full 80A) installed at the family stop there in Hickory now and the garage can be accessed with a PIN if no one is around. (Security cams and all, so, no funny business! ;) ) Recently added it to plugshare, but not sure if it showed up yet. You could probably use it if needed for your trip. I actually may be there June 6-8.
    Taking it easy really makes a difference. I avoid the interstate when possible, even before getting the Model S, just because it generally enforces a more relaxed ride.
