What about a phone line?
RG cable (which one?)
Video cable?
Audio?
Yes, it's very convenient! Went this route some time ago and I am now so spoiled I can't imagine needing to wrap up that heavy cord all the time.An arrangement that allows pulling down the power cable from the ceiling is really convenient.
Excellent idea for the "extra" NEMA 14-50 for additional cars to charge outside...
Really? My garage door is about 7 feet tall and retracts into the garage about 8 feet. On the Roadster, the distance from the nose to the charge port is about 9 feed, and when I back in, I leave a foot and a half in front of the nose. That leaves plenty of clearance for the cord to come down. See my pictures here.I've been trying to figure out how to do this in my garage -- but the natural place where I'd but the power cable on the ceiling is in the middle of where the sliding garage door retracts to, when it's open. Grrr.... I don't see how to do it.
Since the Model S is a much larger car, and since the best rumors put the charge port behind the tail light, the charge location should be at least 12 feet from the front of the garage when backed in.
Sorry, from your earlier posts I did not catch the requirement for front-in parking. Maybe you could build a steel framework just underneath the garage door rails and have the cord-lowering arrangement attached to that?Yeah.... if I back in. But for various site-specific visibility reasons, I'm not sure it's going to be viable to routinely back into my garage. It's much easier to back out.
I'm going to see if I can handle backing in without running into things, first. There are some visibility problems and it involves backing in around a curve (backing out around the curve has much better visibility which is why I'm skeptical).
I may try the steel framework idea but I'll have to find someone who really knows what he's doing to do that -- it's rather beyond me. Thanks for the idea.
Right, that is what I had in mind when I suggested a steel framework. I've often seen it used to mount the garage door opener itself. Depending upon how the garage door rails are attached, it might be possible to couple into that mounting.If you end up going with the steel framework idea, it's fairly easy to build something semi-professional looking using Unistrut. It's like LEGOs for grownups.
I've done this at my house (and the previous house). It's not hard to build a little 4x4x4 foot cage around the cat door to give them an enclosed area in the garage. I just stapled mesh covering over a square framed out of wood.2. Fence in their area.
OK, here's an interesting one:
We have 3 cats. Their litter box is in the garage, and our garage entry door (leading into the house) has a cat door in it. I'm concerned that when I start using the garage door to park the Model S in the garage (we park in the driveway now) that the cats will make a run for it when the door opens. I also don't want paw-prints all over my Model S.
It's a 2-car garage, and I'll be parking head-in on the right side (away from the door that leads inside) so that the litter boxes and cats can be contained in the left half of the garage.
I've been pondering the best way to keep the cats (and their litter) on the left side of the garage. Anyone have any ideas? Maybe cats just won't try to make a break for it when the door opens and a car rolls inside? Seems kinda silly to install some sort of fence or partition down the center of the garage...
This might be a little off topic as it doesn't have anything to do with a charger, but the topic IS "How to design my garage?"
