My BMW is able to display the remaining miles and battery percentage on the dash at the same time. I can't figure out how to do this on my Tesla. Is there a way to display both at the same time?
Yes there is. I have it set up to display the percentage on the instrument cluster, then on the centre screen, constantly show the graph app which shows you range on the right hand side. Best of both worlds.My BMW is able to display the remaining miles and battery percentage on the dash at the same time. I can't figure out how to do this on my Tesla. Is there a way to display both at the same time?
Besides miles is not as accurate as %. It’s an assumption.
In a car 25% lighter no less. Crazy.It's amazing how much more efficient the BMW is. It's somewhere around 25% more efficient with my driving.
Nerp. Miles and percentage are different representations of the exact same data and one is precisely as accurate as the other.
% is based on the battery alone. If I have 100% charge, that doesn’t mean I can actually travel 310 miles. There are external factors that will reduce my efficiency.Nerp. Miles and percentage are different representations of the exact same data and one is precisely as accurate as the other.
Your driving style and geography need to be taken into account.
I believe the Nav’s battery on arrival is a more real time guesstimate.
OP, I didn’t realize I was in the Model S forum where you gave two screens and can display both miles and %.
Exactly the same with miles remaining.% is based on the battery alone. If I have 100% charge, that doesn’t mean I can actually travel 310 miles. There are external factors that will reduce my efficiency.
With either measure, in exactly the same way.Your driving style and geography need to be taken into account.
Agree, that is a forecast, not a real-time representation of measured energy in the battery.I believe the Nav’s battery on arrival is a more real time guesstimate.
@ucmndd I don’t see how they are the same.
% is the actual amount of usable battery.
Miles is an assumption based on EPA figures. It is not impacted by your previous efficiency.
This is the same as having half a tank of gas, it’s actually there, and the car calculating how far it should be able to travel.
Is it really exact tho?
90% day one isn't the same remaining energy as 90% at 100,000 miles.
At least rated miles let's you know you've lost some.
