llavalle
Could be... But I recall a 900 or 950 limited pack(60 perhaps?)but I don't have any logs to check it..note that the S85 limits to 1000 amps, not 900.
Hmm battery temp. So does cooler battery = more power? Just trying to maximize this thing so when I go to impress people I wont be embarrassed, lol. 100% soc, cool weather, no TOC and maybe I can pull 360+ kw?
@llavalle So would you say 360kW at 90+% is normal for a 85D / P85? (they both have about the same acceleration I'm told). Any advice on where to get the adaptor cable + Bluetooth ELM transmitter? Thanks!
It's definitely 1000 amps. I have an S85.
@llavalle darn OK. was hoping something is out there that I can just buy. I certainly have the skills to grab parts and solder things together and make connectors splicing wires together, etc., but I ain't got the time right now!
No soldering involved.
-The CANTact is an open source device (hardware, firmware and software). You can find it here. It has a serial connection (DE-9)
-Bought a serial cable extension from Amazon... cut in half
-Bought the connector and pins from mouser. See this post for details.
-Used the serial cable wires on the pins directly and inserted them in the connector
Took me like 30min... most of which was figuring out which pin in the serial cable was connected to which wire.
If you want to go the ELM way, there's a guy selling pre-made cable on panjo. Here's link (I have no affiliations) : Tesla CAN Diagnostic Cable For MS/MX (Sept 2015 and up) - Crimped to Order OBD-II
Note that this specific cable is for the newer model but I'm sure if you reach out he can probably make one with the older connector (Sept 2015 and older build)
You may have a point. All of the P85 loaners which felt faster all had 21" tires. Mine are 19s.Just a guess, but I'd suspect that the traction control is kicking in to prevent tire slip, so the net effect is that it's ramping up the torque to what the tires can handle. I'll also suspect that the traction control has improved in recent firmware versions as well as probably in your new drive unit such that it isn't noticeable when its limiting torque.
Put some summer performance tires on it and take it to the drag strip where they have a prepped, sticky track. I bet it snaps your head just fine.
Sounds unlikely but is it possible someone installed a non P drive unit by mistake?
So If I buy this cable from Panjo, all I need is an OBD -> bluetooth (or wi-fi like an ELM327?) and TM-Spy on an Android device to log battery stuff?
The OP is reporting power draw that seemingly exceeds the spec of a non-p drive, but under performs compared to the P85 spec. Additionally, this would appear to cause firmware issues since the DU would be flashed with an incorrect firmware. However, note that @wk057 has flashed a standard drive unit with P firmware and turned the car into a P85.
I don't know how I missed the Recent sequential posts on this thread, sorry for the radio silence....and then he went well beyond that turning into a P85+++++ that out accelerates a P85D from a roll.
My best guess is that the battery has degraded and can't put out the same power at the same current that it used to. If the OP can take a CANBUS measurement of voltage and current, I think we'll see a larger voltage drop at 1150 amps in the 295 volt range rather than the 320 volts it should be.
IThanks to an informative post by @llavalle I should be good to go. I see that there are only a couple of parts needed for the cable. Will order that today, and then I already have a Bluetooth obd2, which may or may not work with TM spy. I'll get the CANtact as well in case I can't get the obd device working.
if there is too much margin of error in the app, why not film the speedometer with your smartphone and look at the elapsed time when you play the video?Super tiny update. I got a chance to test it twice on the way to work, using a different app, a simple speed clocker. First 0-60 was 4.5s and the car spent a while at the start struggling to get traction. That matches the Tesla dashboard app measurement from the other day. Second test was baffling. I mashed the gas as much as possible and it seemed to get traction immediately, before it ran to 60 in... 6.1s. Ouch! There was a minor incline here, but nothing i would think that would matter. Maybe these apps have error bars to big to be useful. I will say it didn't feel that fast.
That's outside of the box . I'll see if I can safely get that set up.if there is too much margin of error in the app, why not film the speedometer with your smartphone and look at the elapsed time when you play the video?
That sounds good. I'll order that CANtactI've used this BT:LE dongle with good success : Amazon.com: LELink Bluetooth Low Energy BLE OBD-II OBD2 Car Diagnostic Tool For iPhone/iPod/iPad: Automotive . Works on Android and iOS. Only problem is you can't leave it connected - it messes with the CANBus for some reasons and you might get a DTC. It clears itself up after a few minutes.
The CANTact doesn't do that (messing with the CAN bus). It works great. Contact me via PM if you get the CANtact, I'll give you a few tips
