How to mount FasTrak transponder non-destructively
SeanTek
88
11
After some trial and error, I got my Metro ExpressLanes pass (which is a FasTrak transponder) to work when it is held flush against the plastic at the top-center of the MS windshield, above the rear-view mirror.
What are your suggestions for how to mount the transponder non-destructively, that is, without using the velcro strips? If I use the velcro strips, the strips will look ugly when the transponder is taken off, and will likely leave a residue on the plastic.
I bought a suction device (JL Safety EZ Pass-Port EZP300) that clips the transponder to the windshield. The device works great on the windshield, but will not stay on the plastic above the rear-view mirror because the plastic is not smooth--it has textured ridges. As a result, I guess some adhesive will have to do, but I would prefer a removable and residue-free solution.
artsci
Sponsor
May 10, 2012
6,247
3,217
Timonium, Maryland
Mount it on the front of the crash bar under the nose cone. It works there and is totally stealth.
SeanTek
88
11
Or if you have a front license plate, get a license plate fast trak unit.
In my case it won't work, because the transponder looks like this:
It has a switch to change the number of passengers, so putting it on the nose cone or getting a front license plate-mounted transponder will lose that functionality.
I'll try those other options and report back! Which 3M gray tape, exactly? The strong-looking ones on Amazon.com look like they will not come off cleanly on demand.
lloyds
1,100
205
Bay Area
Hmm...this is the one place I have not tried. I will give this a try and hopefully it solves my transponder issue.
aaron0k
Two failed MCU's on a S40 & S70D; both at 84k.
Apr 1, 2013
664
606
If you want the switch accessible, the only place on the window it will work is in the black/screened area behind the rear view. I currently have mine mounted using the velco tape included. It's ugly though. Since I primarily use it solo, I plan to place it in the nose cone at some point.
jongt3
11
0
Tustin, CA
I put mine in the glove compartment and was surprised that it works just fine there. Definitely works better than mounting on the windshield with the added bonus of being out of sight.
I do not have the transponder with the number of passengers switch.
rallykeeper
248
880
Southern California
It's funny. I've been tossing my FasTrak transponder into the front drivers side corner of my windshield. No tape, just face it backside out (i.e., switches facing down).
I'm not a regular MetroExpress Lane user, but have used it from time to time on the 110 freeway in Los Angeles. In the dozen or so times I've used it over the last six months in my Model S, I've always been charged correctly by MTA.
I'm not sure what to make of that except to say that perhaps my car is being visually checked by photographic evidence if the transponder isn't working.
If you are an infrequent user, that may be the way to go.
SeanTek
88
11
Do you hear it beep when you pass under the detection devices?
gaswalla
Model S,3,X.. CT with Austin delivery
Sep 23, 2012
3,250
3,520
San Diego
I used this stuff (from staples $2..Definitely cheaper elsewhere) and it works great.
chang
149
Dublin, CA
FWIW, this has been working for me: I got the external FasTrak transponder and placed it on the left lower corner of the dash, and it reads! I keep it in the cubby until I'm approaching the station, then pull it out and place it there.
