  • The final cut of the 9th episode of the Tesla Motors Club Podcast, featuring Chad Schwitters, the former president of Plug In America, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
how to mute radio/music during directions on navigation?
On my Model 3, during the navigation directions the Radio/music that is playing is not being muted or even volume lowered so that I can hear navigation direction.
I am not sure if there is a setting some here.
All cars I had sofar automatically mute the Radio/Music during navigation directions. (even android phone does it too). My older Toyota even more clever in reducing the volume of Radio as well as giving Directions only on Drivers side speakers so driver can hear it clearly and others not disturbed much.
Please post if someone found a way to do that.
Thanks in advance.
Reactions: tebling
I noticed this during a test drive and was very surprised that the music volume didn’t lower during nav directions, but I assumed it had to be a setting buried in the menu somewhere.
If the S/X have it and the 3 doesn't, it seems like just one more unfortunate example where the software development on the 3 just wasn't done adequately.
bpjod
536
3,202
Alberta, Canada
I don't know if you can actually mute it (i rented a Model 3 last weekend, but don't have access now to try it out), but I know for sure that the music quieted down some when nav was 'speaking'. You can control the nav's volume while it's 'speaking' simply by using the scroll while while the nav is 'speaking'. Adjust it to where you can clearly hear it over the music.
Reactions: novox77
My Lexus (and Toyota I assume) does it beautifully. Music gets shifted to just the side speakers and center speaker gets the Navi voice. It's beautifully balanced and it doesn't interrupt the music yet still allows me to hear the directions clearly.
It's much more jarring on my Honda. Their whole navi/entertainment system sucks. The Lexus is a lot older, but other than the display quality, it just acts and feels a lot more advanced.
PoitNarf
My dog's breath smells like dog food
Jun 7, 2016
2,870
4,324
NJ
It depends on how loud your music is. If the volume isn’t above a certain threshold it won’t lower the music for the nav directions. Try increasing the volume of the nav prompts, I suspect if that is set to a high enough volume relative to the music volume it will force it to lower the music during nav prompts.
Reactions: Dmagyar and mswlogo
mspohr
10,991
14,093
Thanks in advance.
My Model S mutes the music on the speakers next to the driver and you can adjust the volume of the directions using the icon on the nav screen. Don't know how the Model 3 works but I assume it's the same. I never have any problem hearing directions.
mswlogo
7,562
7,022
MA, NH
+1
Mine works fine and lowers Music from any source for Nav prompts on my Model 3. Works quite good.
To raise volume on Nav prompt, turn the Volume up while it's speaking a Nav command.
Reactions: Dmagyar
Thanks in advance.
There is a separate volume adjustment for the NAV when the Nav is active and you can raise the volume there (settings)
On my 3, the music/radio volume lowers whenever the nav speaks. It's very nice that you can individually change the nav volume from the radio/music as not all cars allow that.
My issue is I need a commute option so when I go to work from home or vice versa the nav just shuts up so I can take advantage of the Nav on Autopilot without her talking over my music.
