I am a non-tech, old man who does not understand how to read//understand the energy display. anyone know of a site for a tutorial.
Sure, feel free to private message me if you have follow up questions.Very helpful....thanks.
That uncertainty goes away if you put a destination in nav and use the trip energy tab. Then it will account for elevation and is quite accurate. All of the other factors except wind are quite minor and will show up in adjusted estimate as you drive. It is worth doing external wind check if you have a tight trip.
Those are all controllable. If most important thing on a leg is range, then the trip chart will tell you 10 miles in that you are going too fast.All true but speed and rate of acceleration are big factors as well. It will do a good job estimating based on past speed but any dramatic changes will have a moderate effect on range.
please go back and read. It wasn't. Someone asked that in post #5. Origianal post was asking for a turorial on how to read the energy graph. I'm not sure where you are coming from. You posted about the Leaf "guess o meter". What does that have to do with the Tesla? Anyway, I think it is important that all Tesla owners understand both energy graphs, and know to how use the trip graph when range really matters... and also know techniques to extend range if/when they get in a pinch.Again, all true but how it tells you is the point. The OP's original question was around the difference between instantaneous vs. average range. I tried to explain how it estimates the range and the difference between those two methods. Yes, you can infer that your current actions have a negative effect on the range but first you must understand what you're looking at. Some, maybe most of us, understand techniques to maximize range but that wasn't the original question.
I find all the electronic terms confusing too. I need "Tesla for Dummies."I am a non-tech, old man who does not understand how to read//understand the energy display. anyone know of a site for a tutorial.
It would be more comparable if they would say "miles per kiloWatt hour" (a thousand watt hours), and we could think of kilo Watt hours as gallons. Unfortunately, "our miles per gallon on electricity" really sucks, as we get around 3 miles per kWh, but it's at least pretty cheap fuel. Our Tesla "gas tank" holds the equivalent of about 3 gallons of gas, but here again, we get pretty good mileage.
Is Ge gallon equivalent?The energy content of a gallon of gasoline is about 33.7 kWh, so 3 miles/KWh is around 100 MPGe. The EPA rated the S85 at 89 MPGe.
Don't you love the units?
