How to remove side mirror covers?
Discussion in 'Model S: Interior & Exterior' started by tdiggity, May 31, 2014.
  1. tdiggity
    tdiggity Member
    Bay Area, CA
    Does anyone know how to remove the side mirror covers? Trying to swap mine out because I scraped mine :(
  2. NigelM
    NigelM Recovering Member
    Northern Virginia
    Do you mean the painted skullcaps? They are fixed on with integrated clips and double sided tape, very difficult to remove without breaking the clips.
  3. swegman
    swegman Active Member
    I had the folding mirror upgrade done to my car, and they swapped the painted skullcaps from the original mirrors onto the folding mirrors. I asked the SC how they did that, and they said there is a special tool for releasing the clips. Without the tool, they said you will most likely break the clips.
  4. tdiggity
    tdiggity Member
    Bay Area, CA
    Thanks guys. I called the SC and they said bring it by and they'd be happy to swap them for me.
  5. flodrab
    flodrab Member
    Venice, CA
    #5 flodrab, Jun 2, 2014
    before you put the new ones on, you might consider getting them wrapped ... I've gotten a lot of compliments about the carbon fiber look I did to mine
  6. MoeMistry
    MoeMistry Local Vendor - SoCal
    Southern California
    Put a small flat plastic tool, they're called little chizzlers, near the far side of the skullcap and wedge it in. Do it gently and you'll hear a snap. Keep following the perimeter with same technique, and viola. No double-sided tape on the ones we've removed.
  7. Terra117
    Terra117 Member
    Edina, MN
    A couple of questions.
    Which side is the far side, and how many clips are there?
    In the photo, it looks like you also removed a trim piece from the bottom of the mirror. Is it part of the top piece, or was it removed separately?
    Also, did you remove the window trim to wrap it, or did you wrap it in place? The edges look very nicely wrapped.
    Thanks.
  8. Anaki01
    Anaki01 Member
    Los Angeles
    I'm also looking to remove my side mirror covers. Anyone have more detailed instructions on how to do this without braking the clips?
  9. ifonul
    ifonul Member
    SAN JOSE
    Quite a few... 6 to be exact. Broke one of the top ones, but it did not matter much when putting it back.
  10. alb92
    alb92 New Member
    Norway
    These clips, are they only on the skullcap itself? I've got a damaged skullcap that I plan on replacing, so not too concerned about breaking clips on the old skullcap. Will forcing it off cause any damage to any part of the mirror itself, such as where the clips click in?
    I'm assuming the new skullcap will just click in. This is for the model X, which I assume is the same as in this thread. Would rather do this myself than go to a SC, as I live far away from the closest, and they are happy to deliver the new skullcap to my door.
