How to remove the center module?
Discussion in 'Model X' started by echin, Jan 1, 2017.
Tags:
  1. echin
    echin Member
    Los Angeles, CA
    I did something stupid... i put a bank check on the center black sliding module (on top of the two cup holders) between the front and passenger seat and the check slid under the sliding platform towards the front of the car... can't reach it from the cup holders... I removed the cup holder plastic pieces and the rubber mat. There are two bolts... will removing allow me to access underneath the big monitor? ;(
  2. habanero69
    habanero69 I Dont Need Cialis. I Drive an EV.
    FLorida
    If you can determine the check #, just place stop payment on it at your financial institution. :) Much easier. Otherwise, you'd probably have to have Tesla service retrieve... :(
  3. SD X
    SD X Member
    San Diego
    Did you ever figure this out? My driver's license found itself in the same location.
  4. echin
    echin Member
    Los Angeles, CA
    I didn’t figure it out... I ended up cancelling the check and a new one was issued. When I took my car in for annual service, i didn’t bother asking them to fetch it.
  5. vandacca
    vandacca ReActive Member
    Hamilton
    I was doing some wiring last weekend and found a receipt in that location. I had removed the carpet/panel on the driver side and was able to see the receipt and extract it with tweezers. Not sure if this would work for you, but just something to consider.
