How To: Retrofit a Model S S85 into a P85
Discussion in 'Model S: Interior & Exterior' started by AC1K, Sep 2, 2013.
  1. AC1K
    AC1K Member
    Calgary Alberta Canada
    Order a P off the internet
    shave off any excess plastic
    apply double sided tape and cut to shape
    cleanse the area
    test fit
    You now have a Performance 85!
    Just kidding, my P was falling off so i had to reapply it.
  2. spentan
    spentan Active Member
    SoCal
    LOL,
    I came in here expecting a very technical procedure on how to hack it to be a performance,
    :p
  3. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    I personally think it was very technical, and a very well done upgrade tutorial. Those "P's" add at minimum 10mph to the top speed! Now, he must do a tutorial on painting it Red, because as any one knows, Red Cars automatically go 3mph faster and accelerate faster then the SpaceX Rockets :)
  4. FlasherZ
    Wait, I always learned from the "type R" forums that yellow cars were the ones that gain an automatic 15 HP advantage?! What gives?!
  5. jak
    jak Member
    Just curious... Can you also retrofit your car into a P85+ with this method as well? :biggrin:
  6. mknox
    mknox Well-Known Member
    Toronto, ON
    Seriously, or were you just kidding about that part too? If the former, do you have a link?
  7. FlasherZ
    In those pictures, it looks as if there's a "bubble" around your badge - just to the inside of the red lines here. The texture appears differently around the badged letters, compared with the rest of the paint.
    Did your car always have this, is this an optical illusion, or is there a texture change where your badge is?
  8. hans
    hans P631
    Menlo Park
    I could be the first person to have a P60!
  9. Puyallup Bill
    Puyallup Bill Member
    Puyallup WA
  10. AC1K
    AC1K Member
    #11 AC1K, Sep 3, 2013
    i think you can get them on Ebay and amazon but im not 100% sure of the font or color, you can definitely get a red R though :)
    EDIT: check it out! http://www.ebay.com/sch/i.html?_odkw=emblems+red+chrome&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.Xred+chrome+emblem&_nkw=red+chrome+emblem&_sacat=0
    you can upgrade to a 5.3L, 7.3L Type R, Type S, Twin Cam, DOHC, Turbo, AWD
    4-5 of these and you can trick out your Model S to the MAX
    i had the car wrapped with Xpel ultimate the shop was too scared to remove the badges or take any trim off so they went around all the hard bits. it turned out ok for $3500, other places are charging $5000, $8000, etc so was it worth it? yeah i guess, its the difference between getting wrapped + winter tires or just getting wrapped.
    you will notice in the "test fit" picture, you kind of see an orange peel like effect instead of just solid paint, that is the paint protection film (PPF) its UV resistance, self healing, and oleophobic (resistant to finger prints and other oily things)
  11. ZBB
    ZBB Emperor
    Scottsdale
    You're not aiming high enough... I'll raise you in my P60+ :biggrin:
