Rusty1
The UI needs work. You should be able to set departure time and off peak separately. The current software requires off peak be on to use departure time.
Right now, I must set off peak time to match departure time. Poor programming.
How it should work- off peak, if enabled, should charge to within 5% of set limit. Charging should finish at departure time to match set limit and have a warm battery.
