dhanson865
My power company charges me super low rates from 12am to 7am. And I have a J1772 charger which will do 32Amp max at my Garage to charge my Model 3 once it comes. I have seen in some video, Tesla can only set the starting charge time, but not end charging time. The maximum charge level could be set though.
Whats the best way to set up , I don’t want the charging go beyond 7am, as it enteres the peak rate.
I am also thinking install a Tesla HPWC which can draw 48amp out of it , so I don’t need worry charging over 7am.
I'd set the car to start charging at 1:01 am (or whatever the smallest time increment past 1am is, I don't know that is minutes, 5 minutes, 15 minutes) with a max charge set at 70% or 80% or whatever you need for a normal days travel.
Why after 1am? Daylight Savings Time.
You won't be charging the full 7 hour window and the utility could bill you wrong around the time change or your time could be off and you could charge at the wrong time.
Ideally you'll charge between 1am and 6am to give yourself a buffer on both ends for time changes or a clock being off by a few minutes.
Unless you drive your car to near 0% all the time 5 hours should be plenty at 32 amps and will definitely be plenty at 48 amps.
