How To Show Your Car At A Car Show
Discussion in 'Model S' started by Skotty, Apr 29, 2017.
Tags:
  1. Skotty
    Skotty 2014 Model S P85
    Kansas City, MO
    So I know this has come up before somewhere, but i want to hit on it again. I've started taking my car to some car shows. Despite the S having been around awhile, it still draws a lot of attention and interested people. So it's definitely worth doing.
    The question is, in what state do you leave your car in so that you can show it but without there being excessive safety concerns.
    The problem is, there doesn't seem to be a way to put the "ignition" in "accessory" mode, such that you can interact with the controls but the car can't go anywhere. The automatic break release also isn't helpful in a car show situation.
    True, in an old ICE, you are just a key turn away from potentially starting the car, but you still have to put in drive or reverse and maybe release a parking break, and that still takes a rather significant deliberate act. I feel like there is a higher risk of an accident with a Tesla, as so long as the key is nearby, all someone has to do is push the gear stalk up or down and it's essentially driving.
    How have some of you handled this when showing your car at a car show? Is there an option in the UI I'm not thinking about that helps? I could just leave the car off, but it's a show, and you are showing quite a bit less with the car off and the screen dark. I suppose I could block the wheels, but that feels kind of like a band aid solution. I guess another option is just try to keep the driver seat off limits.
    Thanks for any suggestions.
  2. soccerMX
    soccerMX Member
    San Jose, CA
    You can put the car in "NEUTRAL" and turn ON the parking brake while its in neutral. The car will remain in the ON state.
  3. Saghost
    Saghost Well-Known Member
    Delaware
    #3 Saghost, Apr 29, 2017
    The traditional answer is to plug the UMC or J1772 adaptor in. The car won't move while plugged in, and someone would have to go through several specific steps (unlock charge port, then unplug, then get in and hit the brake) to activate the car.
    Having the UMC sitting there is also a good visual aid and can lead to better conversations about charging.
    Edit: Don't use the J1772 for this - it won't work!! I was passing along what I read, but afterwards I was pondering how the car knew the J1772 was there, so I went out and tried it. The car will happily turn on and shift to drive if just the J1772 adaptor is in the port (but not if plugged into a J1772 source, of course.) The UMC will disable the car, as promised.
  4. Skotty
    Kansas City, MO
    Oooh, interesting idea. So it doesn't actually need to be plugged in on the wall side, but you can still plug it in on the car side and basically disable the drive? I'll try that later tonight. Thanks for the tip!
  5. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    It's too bad you don't have access to 'showroom' mode. As I recall, some electronics work, FWD are open, can't be closed (and worn out), car can't be started, brake pedal closes driver door (good demo), etc.
  6. Saghost
    Delaware
    #6 Saghost, Apr 29, 2017
    Correct. The car won't move if the UMC plugged into the port, whether or not it's plugged into the wall. The J1772 does not in fact work for this unless you also have a J1772 cable plugged in to it.
  7. Red_DS
    Red_DS Member
    New York
    Have you asked your local Tesla gallery about showroom mode? That's what they have the cars in the gallery set to. It's a code they input after pressing and holding the T on the center screen for a few seconds.
    • Helpful x 2
  8. Saghost
    Delaware
    #8 Saghost, Apr 29, 2017
    Also, if you're going to car shows, I recommend one of these. It's been very amusing to the crowds where I went and served as a nice ice-breaker/fascinator. I leave it in an otherwise empty frunk and introduce it as the real power source. I've been considering whether I need to upgrade to a multi-hamster array:
    Amazon.com: Happy Hamster Pet with WHEEL RUNNER Battery Operated Kid's Toy: Toys & Games
    • Funny x 5
  9. AEdennis
    AEdennis Active Member
    That's a classic!
  10. Btrflyl8e
    Btrflyl8e Supporting Member
    Seminole, Florida, United States
    I leave mine off at car shows, so I can secretly engage Summon! Talk about attracting a crowd...they never suspect the girl.
    • Funny x 3
  11. NeverFollow
    NeverFollow Active Member
    I recently requested a car insurance quote, and one question was if I was taking my car to some car show?
    I know some people doing it in fact to help some charities fundraisers like United Way,
    and I think that they can deduct some expenses to their IRS taxes.
    However, I wonder how this could affect my insurance, and in which way?
  12. berkeley_ecar
    berkeley_ecar S 90D (fully loaded) delivered 18 Mar 2017
    Berkeley, CA
    Interesting. When I added my S to my insurance policy, they didn't ask this question, but did ask if I intended to use the vehicle in connection with any ride sharing services!
  13. mdX-
    mdX- Member
    Sioux City, IA
    IMG_7185.JPG I just did my first car show, Great Fun. Harbor Springs Michigan's 11th annual drew some 40+ entrants and 700+ Viewers And my X 90D was the showstopper!
    I played the Model Xmas Show on the half hour to everyone's delight.
    So all you Xers out there, go Xmas Show Away!!!
