New owners aware: you are not a good driver if you never drain the mileage close to 0, and you will always be bothered with range anxiety. Once you have this experience, you will get rid of the range anxiety. So you should try it once you have a chance. By doing so, Xiaomage has been cured hundreds of people who have range anxiety, including female drivers. For now, his best record is -28 km, he also created a new word – mileage below 0.
Changing mileage to mileage percentage is the best way to cure range anxiety. Turning the Tesla AC on uses 8km/h. AC plus seat heater use 12 km/h. The car itself uses 5 km per day. One of the Chengdu owners had a close call, the mileage says 181 km, but he actually drove 215.2 KM, which is 7 km below 0. The speed was 50km/h, the trip took 4.55 hours and the average energy is 136.
Xiaomage doesn’t recommend draining the mileage below 0. The correct way is to prepare 3 important things in the car: industrial outlet box, electricity cable and Trolley rope. Once the mileage is getting to 0, find a car repair shop to charge, all the highway exits have a car repair shop within 200 meters. You can fix it within 100 RMB. You can also use trolley cable. Once you have these 3 things you can travel all over the country without worrying run out of power.
