The app will say it at the end of the charging sessionHi All
Does anyone know how you can tell from the in car stats how much charge you put in to the car on your last charge?
I am going to be charging from the granny charger for a while and need to know how much charge in KWh I have added each time I charge the car.
Thanks
You can scroll across the bar chart in the app's "Charge Stats" tab to get daily kWh charging info, if that works in your scenario.Hi All
Thanks
Why do you need to know? The amount that reaches the battery will be less than what you used.I am going to be charging from the granny charger for a while and need to know how much charge in KWh I have added each time I charge the car.
Thanks
Found to my pain that this only works if you're the primary key holder/owner. So it shows on my wife's app, who couldn't give a hoot and I can't see it, I have to borrow her phone to look.You can scroll across the bar chart in the app's "Charge Stats" tab to get daily kWh charging info, if that works in your scenario.
or you do the maths:Hi All
Thanks
Charge stats tab?? Is that on the mobile app? If so where as I don't see it?You can scroll across the bar chart in the app's "Charge Stats" tab to get daily kWh charging info, if that works in your scenario.
It's a company car and the company will refund the cost of the charge based against my current home electric rate, but I need to know how much juice went in to the car so the cost can be calculated..Why do you need to know? The amount that reaches the battery will be less than what you used.
Unless you want to subsidise the cost, you'll be paying more than any car based app will record. There are (quite substantial) losses in the journey between mains power and your car's battery. Best to get one of the plug in energy meters (such as this) to record what you're actually using rather than what ends up in the car.It's a company car and the company will refund the cost of the charge based against my current home electric rate, but I need to know how much juice went in to the car so the cost can be calculated..
If anyone has a way to do this just using the app or the applications already on the car that would be a great help.
It's ok saying her Teslafi or Teslamate or any other 3rd party tools, but need this workable with the basics i have available ..
Thanks
Ahh nice that's the kinda idea I was hoping for.. thanksUnless you want to subsidise the cost, you'll be paying more than any car based app will record. There are (quite substantial) losses in the journey between mains power and your car's battery. Best to get one of the plug in energy meters (such as this) to record what you're actually using rather than what ends up in the car.
That's just the first one I found on Google when I searched. Do have a good look yourself to see if there is anything better for your needs.Ahh nice that's the kinda idea I was hoping for.. thanks
It's the sixth option in the current iPhone app's list for the car, between "Security & Drivers" and "Upgrades". Yes, I'm using the word "tab" rather loosely...Charge stats tab?? Is that on the mobile app? If so where as I don't see it?
Thanks
The Tessie app shows both how much the car battery has added and also how much has been used in total.Ahh nice that's the kinda idea I was hoping for.. thanks
I presume it's just calculating the same way that Teslamate and Teslafi do, by multiplying the supply voltage, current and phases?The Tessie app shows both how much the car battery has added and also how much has been used in total.
I’ve no idea how it does it! Strangely it’s a different calculation for each charge so it’s not a consistent percentage overhead.I presume it's just calculating the same way that Teslamate and Teslafi do, by multiplying the supply voltage, current and phases?
These are the options I have with the latest app..It's the sixth option in the current iPhone app's list for the car, between "Security & Drivers" and "Upgrades". Yes, I'm using the word "tab" rather loosely...
The odd thing is that looking at several charges in Tessie shows 100% for some charges and down at 84% for others. I don’t see how you can actually have 100% … that is exactly the same amount added as the charger used. (All on ac home charger) something appears to be amiss, at least for the 100% ones.Found it!
Charging Efficiency - Help Center - Tessie
During charging, Tessie can measure the energy added to the battery, used by the charger and the overall efficiency. Energy Added Your Tesla tracks the energy ahelp.tessie.com
Same calc as the others. I checked one of my (rare) home charges and there's a 0.8kw difference on a 3 hour charge between what my charge point says was used and the calculation. I suspect that the sampling interval will influence the calculation. Might not be a lot of difference in the grand scheme of things, but if the OP wants to get as much money out of their company as possible, every little helps![]()
