Alright, probably a stupid question, but is there a way to tell that the cabin heater is being used besides feeling warm air coming out of the vents? I know it is more energy efficient to use the seat heaters, but how do I know the heat from the HVAC system is off? Thanks.
Not near my car right now, but I think the air flow graphic (if you hit the fan icon) will show a hint of red if heat is on.
As far as I know there is no separate display in car to show you the PTC heater is working. There is also no way to disable the heat for a fan only effect. A shame as that would be a great range saving feature.
One trick I use is set temperature to “LO” and set fan to 1. This seems to turn the heater off. This works when humidity is good and temperature is in the mid 40s to 60s. I turn on the seat heater as needed.
Yeah as long as you disengage the AC this should work well. I wish they'd just give us a button for it so I could leave it in auto with heat off though!
The airflow "display" used to actually change color to denote which system was on; in like mid to late 2018 they changed it the the basic white we see now.
The display in the Phone APP will toggle between Red for Heating, White for nothing, and Blue for Cooling. Caveat with that is that when it is White, it might be lying to you.
