How viable is Solar City's distributed solar concept?
jerry33
Mar 8, 2012
19,529
21,748
Texas
If you have 15% of an area's power coming from non-grid sources, it results in the grid being less stressed and upgrades to the grid will happen less frequently. However, the cost of individual generation is higher per kWh than at a centrally located facility. (That is the true cost assuming zero subsidies). A better approach, in my opinion, is a neighbourhood wind power facility. This is done in Europe and is generally wind powered although solar is catching up. This scales the production up so there are some economies of scale and reduces transmission costs. It's also relatively cheap to build. A neighbourhood generation station will cost less to build per kWh generated than 200 or 300 individual installations, although it will still be far more expensive than a sensible nuclear plant.
jerry33
Mar 8, 2012
19,529
21,748
Texas
The "net metering" approach--which basically lets PV owners use the grid infrastructure for free--is undermining the cash flows utilities need to modernize the grid:
Solar Panels Cast Shadow on U.S. Utility Rate Design – Fitch Ratings
This assumes that the now privatized utilities would actually use the extra funds to modernize the grid rather than just taking the money and using the existing infrastructure as a cash cow. I don't count on privatized utilities doing anything but raising rates and lowering service.
Robert.Boston
Model S VIN P01536
Oct 7, 2011
7,844
36
Portland, Maine, USA
Jerry, I'm puzzled by your term "privatized utility." Thomas Edison created the first electric utility in New York City as a private company subject to government regulation. That basic model hasn't changed in 140 years. You are right to have a skeptical POV on utilities, but your post suggests that something has changed in your lifetime.
Tim
82
36
This article is FUD. Regulated utilities negotiate their capex for line extensions/upgrades/rebuild every couple of years. Their cash-flow is predetermined. Fitch is basically complaining that a large increase in net metering could eventually cause a power surplus in localized areas and a higher burden on utilities due to lower utilization of power plants. Maybe, but I don't buy it. Apparently neither do the electric commissions in the states quoted. I'm not sure about net-metering in all states, but I certainly don't use the grid for free. I pay interconnection fees the same as anyone else. In any event the power industry in the u.s. has a bunch of soon to be obsolete coal plants so maybe this isn't so much a problem as it is a solution.
Ampster
1,645
420
Sonoma, California
I won't try to interpret what Jerry meant, but I can tell you that the public utility regulations were significantly changed in California in the last 20 years. SCE sold off some of their generating capacity,
jerry33
Mar 8, 2012
19,529
21,748
Texas
I should have said deregulated rather than privatized. My bad choice of wording there.
Ampster
1,645
420
Sonoma, California
I may be using the grid "for free" but I am also providing a service because I am generating during peak hours and consuming during off peak. In California the annual "true up" is at wholesale rates so SCE benefits as well.
